Ir para o conteúdo principal
Mac Studio 2023 Power Button Replacement
O que você precisa
  1. Mac Studio 2023 Power Button Replacement, Prepare your Mac Studio for disassembly: passo 1, imagem 1 %32 Mac Studio 2023 Power Button Replacement, Prepare your Mac Studio for disassembly: passo 1, imagem 2 %32 Mac Studio 2023 Power Button Replacement, Prepare your Mac Studio for disassembly: passo 1, imagem 3 %32
    • Completely shut down your Mac Studio.
    • Unplug all cables from your device.
  2. Mac Studio 2023 Power Button Replacement, Flip your Mac Studio over: passo 2, imagem 1 %32
    • Flip your Mac Studio over and lay it down so the bottom faces up and the SD card slot and two front USB‑C ports are facing you.
  3. Mac Studio 2023 Power Button Replacement, Heat the bottom cover screw pad: passo 3, imagem 1 %32 Mac Studio 2023 Power Button Replacement, Heat the bottom cover screw pad: passo 3, imagem 2 %32 Mac Studio 2023 Power Button Replacement, Heat the bottom cover screw pad: passo 3, imagem 3 %32
    • Adhesive strips secure the bottom cover screw pad.
    • Heat an iOpener and lay it over one of the bottom cover screws for two minutes to soften the adhesive near the screw—this is where you'll insert a spudger in the next step.
    • You can also use a hair dryer or heat gun, but be careful as extreme heat will warp the pad.
  4. Mac Studio 2023 Power Button Replacement, Lift a section of bottom cover screw pad: passo 4, imagem 1 %32 Mac Studio 2023 Power Button Replacement, Lift a section of bottom cover screw pad: passo 4, imagem 2 %32 Mac Studio 2023 Power Button Replacement, Lift a section of bottom cover screw pad: passo 4, imagem 3 %32
    • Insert the point of a spudger under the pad's inner edge, near the screw you applied heat to in the previous step.
    • This may take some force. If you're having trouble, apply more heat and try again.
    • Use the spudger to lift the pad and separate the adhesive.
  5. Mac Studio 2023 Power Button Replacement, Separate the remaining adhesive: passo 5, imagem 1 %32 Mac Studio 2023 Power Button Replacement, Separate the remaining adhesive: passo 5, imagem 2 %32 Mac Studio 2023 Power Button Replacement, Separate the remaining adhesive: passo 5, imagem 3 %32
    • Insert the flat end of a spudger under the pad.
    • Slide the spudger under the entire pad to separate the remaining adhesive.
  6. Mac Studio 2023 Power Button Replacement, Remove the bottom cover screw pad: passo 6, imagem 1 %32
    • Remove the bottom cover screw pad.
  7. Mac Studio 2023 Power Button Replacement, Reassembly information: passo 7, imagem 1 %32 Mac Studio 2023 Power Button Replacement, Reassembly information: passo 7, imagem 2 %32 Mac Studio 2023 Power Button Replacement, Reassembly information: passo 7, imagem 3 %32
    Ferramenta utilizada neste passo:
    Tesa 61395 Tape
    $2.99
    • During reassembly:
    • If the adhesive strips are still sticky, you can reuse them.
    • If you're applying new adhesive:
    • Use the flat end of a spudger and your fingers to scrape up and remove the old adhesive strips.
    • Use isopropyl alcohol and a microfiber cloth to remove the old adhesive residue.
    • If you don't have replacement adhesive, you can use strips of thin, double-sided tape 2–3 mm wide.
    • Apply the new adhesive strips to the bottom cover and remove their liners.
    • Firmly press the bottom cover screw pad into its recess to secure it.
  8. Mac Studio 2023 Power Button Replacement, Remove the bottom cover screws: passo 8, imagem 1 %32 Mac Studio 2023 Power Button Replacement, Remove the bottom cover screws: passo 8, imagem 2 %32
    FixMat
    $36.95
    • While the Mac Studio uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
    • Use a T10 Torx screwdriver to remove the four 8 mm‑long screws securing the bottom cover.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came.
  9. Mac Studio 2023 Power Button Replacement, Remove the bottom cover: passo 9, imagem 1 %32 Mac Studio 2023 Power Button Replacement, Remove the bottom cover: passo 9, imagem 2 %32 Mac Studio 2023 Power Button Replacement, Remove the bottom cover: passo 9, imagem 3 %32
    • Insert the point of a spudger in one of the bottom cover's ventilation holes and lift the cover until you can grab it with your fingers.
    • Remove the bottom cover.
    • To orient the bottom cover, align the Kensington lock cutout in the top left corner with the corresponding one on the internal frame.
  10. Mac Studio 2023 Power Button Replacement, Remove the power supply screws: passo 10, imagem 1 %32 Mac Studio 2023 Power Button Replacement, Remove the power supply screws: passo 10, imagem 2 %32
    • Use a T10 Torx screwdriver to remove the six screws securing the power supply:
    • Four 6 mm‑long screws
    • Two 7 mm‑long screws with washers
    • You may need to remove a sticker to access these screws. If you do, save it for reassembly.
  11. Mac Studio 2023 Power Button Replacement, Reposition your Mac Studio: passo 11, imagem 1 %32
    • Flip your Mac Studio around so the rear ports are facing you.
  12. Mac Studio 2023 Power Button Replacement, Disconnect the power cord port cable: passo 12, imagem 1 %32 Mac Studio 2023 Power Button Replacement, Disconnect the power cord port cable: passo 12, imagem 2 %32 Mac Studio 2023 Power Button Replacement, Disconnect the power cord port cable: passo 12, imagem 3 %32
    • A tight plastic latch secures the power cord port cable.
    • Firmly hold the power supply with one hand and lift up the edge near the power cord port.
    • With your free hand, pinch the head of the power cord port connector to unclip it and pull straight down to disconnect the cable.
  13. Mac Studio 2023 Power Button Replacement, Tilt up the power supply: passo 13, imagem 1 %32
    • Only grab the power supply by its edges. Various power components and capacitors are left exposed.
    • Carefully tilt the power supply away from the power cord port so it's at a 90-degree angle.
    • Be careful not to strain the cable that's still connected to the power supply.
    • Keep the power supply tilted up for the next step.
  14. Mac Studio 2023 Power Button Replacement, Disconnect the power supply signal cable: passo 14, imagem 1 %32 Mac Studio 2023 Power Button Replacement, Disconnect the power supply signal cable: passo 14, imagem 2 %32 Mac Studio 2023 Power Button Replacement, Disconnect the power supply signal cable: passo 14, imagem 3 %32
    • A delicate plastic clip secures the power supply signal cable.
    • With your free hand, pinch the head of the power supply connector to unclip it and pull straight away from the socket to disconnect the cable.
  15. Mac Studio 2023 Power Button Replacement, Remove the power supply: passo 15, imagem 1 %32
    • Remove the power supply.
  16. Mac Studio 2023 Power Button Replacement, Reposition your Mac Studio: passo 16, imagem 1 %32
    • Flip your Mac Studio around so the SD card reader and two front USB‑C ports are facing you.
  17. Mac Studio 2023 Power Button Replacement, Remove the internal frame screws: passo 17, imagem 1 %32 Mac Studio 2023 Power Button Replacement, Remove the internal frame screws: passo 17, imagem 2 %32
    • Use a T6 Torx screwdriver to remove the eight screws securing the internal frame:
    • Seven 5 mm‑long screws
    • One 4 mm‑long screw
  18. Mac Studio 2023 Power Button Replacement, Remove the internal frame: passo 18, imagem 1 %32 Mac Studio 2023 Power Button Replacement, Remove the internal frame: passo 18, imagem 2 %32
  19. Mac Studio 2023 Power Button Replacement, Remove the speaker screws: passo 19, imagem 1 %32 Mac Studio 2023 Power Button Replacement, Remove the speaker screws: passo 19, imagem 2 %32 Mac Studio 2023 Power Button Replacement, Remove the speaker screws: passo 19, imagem 3 %32
    • Use a T5 Torx screwdriver to remove the two 12 mm‑long screws securing the speaker.
  20. Mac Studio 2023 Power Button Replacement, Reposition the speaker: passo 20, imagem 1 %32 Mac Studio 2023 Power Button Replacement, Reposition the speaker: passo 20, imagem 2 %32 Mac Studio 2023 Power Button Replacement, Reposition the speaker: passo 20, imagem 3 %32
  21. Mac Studio 2023 Power Button Replacement, Disconnect the speaker: passo 21, imagem 1 %32 Mac Studio 2023 Power Button Replacement, Disconnect the speaker: passo 21, imagem 2 %32
    • Insert the point of a spudger under the speaker connector's plastic head and carefully lift it straight up and out of its socket.
    • Don't lift on the wires themselves, or you may damage them.
    • To reconnect the cable, position the connector head over its socket and press to with the flat end of a spudger—the connector should click into place.
  22. Mac Studio 2023 Power Button Replacement, Remove the speaker: passo 22, imagem 1 %32
    • Remove the speaker.
  23. Mac Studio 2023 Power Button Replacement, Remove the cable cover screws: passo 23, imagem 1 %32 Mac Studio 2023 Power Button Replacement, Remove the cable cover screws: passo 23, imagem 2 %32
    • Use a T3 Torx screwdriver to remove the two 2 mm‑long screws securing the I/O board cable cover.
    • Use a T8 Torx screwdriver to remove the standoff screw just to the right of the cover.
  24. Mac Studio 2023 Power Button Replacement, Remove the cover: passo 24, imagem 1 %32
    • Use tweezers or your fingers to remove the I/O board cable cover.
  25. Mac Studio 2023 Power Button Replacement, Disconnect the I/O board: passo 25, imagem 1 %32 Mac Studio 2023 Power Button Replacement, Disconnect the I/O board: passo 25, imagem 2 %32 Mac Studio 2023 Power Button Replacement, Disconnect the I/O board: passo 25, imagem 3 %32
    • Be very careful not to scrape off or damage any surface mounted components during this step.
    • Use a spudger to pry up and disconnect both of the I/O board's press connectors.
    • To reconnect press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  26. Mac Studio 2023 Power Button Replacement, Disconnect the power button: passo 26, imagem 1 %32 Mac Studio 2023 Power Button Replacement, Disconnect the power button: passo 26, imagem 2 %32 Mac Studio 2023 Power Button Replacement, Disconnect the power button: passo 26, imagem 3 %32
    • Use the point of a spudger or a clean fingernail to flip up the hinged locking flap on the power button cable ZIF connector, located on the outer edge of the I/O board.
    • Use tweezers to gently pull the cable straight out of its socket.
  27. Mac Studio 2023 Power Button Replacement, Reposition your Mac Studio: passo 27, imagem 1 %32
    • Carefully stand up your Mac Studio so the SD card reader and two front USB-C ports are facing up.
  28. Mac Studio 2023 Power Button Replacement, Remove the I/O board screws: passo 28, imagem 1 %32 Mac Studio 2023 Power Button Replacement, Remove the I/O board screws: passo 28, imagem 2 %32 Mac Studio 2023 Power Button Replacement, Remove the I/O board screws: passo 28, imagem 3 %32
    Flexible Extension
    $6.99
    • These screws may be hard to access. If you can't insert your screwdriver properly, use a flexible extension to avoid stripping screws or damaging the logic board.
    • Use a T4 Torx screwdriver to remove the two 15.5 mm‑long screws securing the outer edge of the I/O board.
    • Use a T6 Torx screwdriver to remove the two 20 mm‑long screws securing the inner edge of the I/O board.
    • Partially tighten the four screws securing the board.
    • Lay your Mac Studio down and plug a cable into one of the ports to ensure proper fit and alignment, adjusting the port as necessary—the cable should be easy to insert and remove.
    • With the cable plugged in and the board in position, fully tighten all four screws.
    • Unplug all cables before continuing.
  29. Mac Studio 2023 Power Button Replacement, Remove the I/O board: passo 29, imagem 1 %32 Mac Studio 2023 Power Button Replacement, Remove the I/O board: passo 29, imagem 2 %32 Mac Studio 2023 Power Button Replacement, Remove the I/O board: passo 29, imagem 3 %32
    • Lift the I/O board straight up and out of its recess to remove it.
    • During reassembly, lower the board into its recess, making sure the press connectors don't get trapped under the logic board.
  30. Mac Studio 2023 Power Button Replacement, Remove the power button screws: passo 30, imagem 1 %32 Mac Studio 2023 Power Button Replacement, Remove the power button screws: passo 30, imagem 2 %32
    Flexible Extension
    $6.99
  31. Mac Studio 2023 Power Button Replacement, Remove the power button: passo 31, imagem 1 %32
    • Remove the power button.
Conclusão
Spencer Day
Membro desde: 09/14/22
154.631 Reputação
Autoria de 1.033 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.755 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 54
Ao todo: 488
