Ir para o conteúdo principal
Mac Studio 2023 Fans Replacement
O que você precisa
  1. Mac Studio 2023 Fans Replacement, Prepare your Mac Studio for disassembly: passo 1, imagem 1 %32 Mac Studio 2023 Fans Replacement, Prepare your Mac Studio for disassembly: passo 1, imagem 2 %32 Mac Studio 2023 Fans Replacement, Prepare your Mac Studio for disassembly: passo 1, imagem 3 %32
    • Completely shut down your Mac Studio.
    • Unplug all cables from your device.
  2. Mac Studio 2023 Fans Replacement, Flip your Mac Studio over: passo 2, imagem 1 %32
    • Flip your Mac Studio over and lay it down so the bottom faces up and the SD card slot and two front USB‑C ports are facing you.
  3. Mac Studio 2023 Fans Replacement, Heat the bottom cover screw pad: passo 3, imagem 1 %32 Mac Studio 2023 Fans Replacement, Heat the bottom cover screw pad: passo 3, imagem 2 %32 Mac Studio 2023 Fans Replacement, Heat the bottom cover screw pad: passo 3, imagem 3 %32
    • Adhesive strips secure the bottom cover screw pad.
    • Heat an iOpener and lay it over one of the bottom cover screws for two minutes to soften the adhesive near the screw—this is where you'll insert a spudger in the next step.
    • You can also use a hair dryer or heat gun, but be careful as extreme heat will warp the pad.
  4. Mac Studio 2023 Fans Replacement, Lift a section of bottom cover screw pad: passo 4, imagem 1 %32 Mac Studio 2023 Fans Replacement, Lift a section of bottom cover screw pad: passo 4, imagem 2 %32 Mac Studio 2023 Fans Replacement, Lift a section of bottom cover screw pad: passo 4, imagem 3 %32
    • Insert the point of a spudger under the pad's inner edge, near the screw you applied heat to in the previous step.
    • This may take some force. If you're having trouble, apply more heat and try again.
    • Use the spudger to lift the pad and separate the adhesive.
  5. Mac Studio 2023 Fans Replacement, Separate the remaining adhesive: passo 5, imagem 1 %32 Mac Studio 2023 Fans Replacement, Separate the remaining adhesive: passo 5, imagem 2 %32 Mac Studio 2023 Fans Replacement, Separate the remaining adhesive: passo 5, imagem 3 %32
    • Insert the flat end of a spudger under the pad.
    • Slide the spudger under the entire pad to separate the remaining adhesive.
  6. Mac Studio 2023 Fans Replacement, Remove the bottom cover screw pad: passo 6, imagem 1 %32
    • Remove the bottom cover screw pad.
  7. Mac Studio 2023 Fans Replacement, Reassembly information: passo 7, imagem 1 %32 Mac Studio 2023 Fans Replacement, Reassembly information: passo 7, imagem 2 %32 Mac Studio 2023 Fans Replacement, Reassembly information: passo 7, imagem 3 %32
    Ferramenta utilizada neste passo:
    Tesa 61395 Tape
    $2.99
    • During reassembly:
    • If the adhesive strips are still sticky, you can reuse them.
    • If you're applying new adhesive:
    • Use the flat end of a spudger and your fingers to scrape up and remove the old adhesive strips.
    • Use isopropyl alcohol and a microfiber cloth to remove the old adhesive residue.
    • If you don't have replacement adhesive, you can use strips of thin, double-sided tape 2–3 mm wide.
    • Apply the new adhesive strips to the bottom cover and remove their liners.
    • Firmly press the bottom cover screw pad into its recess to secure it.
  8. Mac Studio 2023 Fans Replacement, Remove the bottom cover screws: passo 8, imagem 1 %32 Mac Studio 2023 Fans Replacement, Remove the bottom cover screws: passo 8, imagem 2 %32
    FixMat
    $36.95
    • While the Mac Studio uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
    • Use a T10 Torx screwdriver to remove the four 8 mm‑long screws securing the bottom cover.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came.
  9. Mac Studio 2023 Fans Replacement, Remove the bottom cover: passo 9, imagem 1 %32 Mac Studio 2023 Fans Replacement, Remove the bottom cover: passo 9, imagem 2 %32 Mac Studio 2023 Fans Replacement, Remove the bottom cover: passo 9, imagem 3 %32
    • Insert the point of a spudger in one of the bottom cover's ventilation holes and lift the cover until you can grab it with your fingers.
    • Remove the bottom cover.
    • To orient the bottom cover, align the Kensington lock cutout in the top left corner with the corresponding one on the internal frame.
  10. Mac Studio 2023 Fans Replacement, Remove the power supply screws: passo 10, imagem 1 %32 Mac Studio 2023 Fans Replacement, Remove the power supply screws: passo 10, imagem 2 %32
    • Use a T10 Torx screwdriver to remove the six screws securing the power supply:
    • Four 6 mm‑long screws
    • Two 7 mm‑long screws with washers
    • You may need to remove a sticker to access these screws. If you do, save it for reassembly.
  11. Mac Studio 2023 Fans Replacement, Reposition your Mac Studio: passo 11, imagem 1 %32
    • Flip your Mac Studio around so the rear ports are facing you.
  12. Mac Studio 2023 Fans Replacement, Disconnect the power cord port cable: passo 12, imagem 1 %32 Mac Studio 2023 Fans Replacement, Disconnect the power cord port cable: passo 12, imagem 2 %32 Mac Studio 2023 Fans Replacement, Disconnect the power cord port cable: passo 12, imagem 3 %32
    • A tight plastic latch secures the power cord port cable.
    • Firmly hold the power supply with one hand and lift up the edge near the power cord port.
    • With your free hand, pinch the head of the power cord port connector to unclip it and pull straight down to disconnect the cable.
  13. Mac Studio 2023 Fans Replacement, Tilt up the power supply: passo 13, imagem 1 %32
    • Only grab the power supply by its edges. Various power components and capacitors are left exposed.
    • Carefully tilt the power supply away from the power cord port so it's at a 90-degree angle.
    • Be careful not to strain the cable that's still connected to the power supply.
    • Keep the power supply tilted up for the next step.
  14. Mac Studio 2023 Fans Replacement, Disconnect the power supply signal cable: passo 14, imagem 1 %32 Mac Studio 2023 Fans Replacement, Disconnect the power supply signal cable: passo 14, imagem 2 %32 Mac Studio 2023 Fans Replacement, Disconnect the power supply signal cable: passo 14, imagem 3 %32
    • A delicate plastic clip secures the power supply signal cable.
    • With your free hand, pinch the head of the power supply connector to unclip it and pull straight away from the socket to disconnect the cable.
  15. Mac Studio 2023 Fans Replacement, Remove the power supply: passo 15, imagem 1 %32
    • Remove the power supply.
  16. Mac Studio 2023 Fans Replacement, Reposition your Mac Studio: passo 16, imagem 1 %32
    • Flip your Mac Studio around so the SD card reader and two front USB‑C ports are facing you.
  17. Mac Studio 2023 Fans Replacement, Remove the internal frame screws: passo 17, imagem 1 %32 Mac Studio 2023 Fans Replacement, Remove the internal frame screws: passo 17, imagem 2 %32
    • Use a T6 Torx screwdriver to remove the eight screws securing the internal frame:
    • Seven 5 mm‑long screws
    • One 4 mm‑long screw
  18. Mac Studio 2023 Fans Replacement, Remove the internal frame: passo 18, imagem 1 %32 Mac Studio 2023 Fans Replacement, Remove the internal frame: passo 18, imagem 2 %32
  19. Mac Studio 2023 Fans Replacement, Remove the antenna cable cover: passo 19, imagem 1 %32 Mac Studio 2023 Fans Replacement, Remove the antenna cable cover: passo 19, imagem 2 %32 Mac Studio 2023 Fans Replacement, Remove the antenna cable cover: passo 19, imagem 3 %32
    • Use a T3 Torx screwdriver to remove the two 2 mm‑long screws securing the antenna cable cover.
    • Use tweezers or your fingers to remove the cover.
  20. Mac Studio 2023 Fans Replacement, Disconnect antenna 2: passo 20, imagem 1 %32 Mac Studio 2023 Fans Replacement, Disconnect antenna 2: passo 20, imagem 2 %32
    • Insert one arm of a pair of angled tweezers under the metal neck of antenna 2's coaxial connector and lift straight up to disconnect it.
    • To reconnect the cable, hold the connector in place over its socket and press down with the flat end of a spudger—the connector should snap into place. If you're having trouble, don't try to force the connector over the socket. Reposition it and try again.
  21. Mac Studio 2023 Fans Replacement, Remove antenna 2's screws: passo 21, imagem 1 %32 Mac Studio 2023 Fans Replacement, Remove antenna 2's screws: passo 21, imagem 2 %32
    • Use a T5 Torx screwdriver to remove the two 3.5 mm‑long screws securing antenna 2.
  22. Mac Studio 2023 Fans Replacement, Remove antenna 2: passo 22, imagem 1 %32 Mac Studio 2023 Fans Replacement, Remove antenna 2: passo 22, imagem 2 %32
    • Remove antenna 2.
  23. Mac Studio 2023 Fans Replacement, Disconnect antenna 3: passo 23, imagem 1 %32 Mac Studio 2023 Fans Replacement, Disconnect antenna 3: passo 23, imagem 2 %32 Mac Studio 2023 Fans Replacement, Disconnect antenna 3: passo 23, imagem 3 %32
    • Insert one arm of a pair of angled tweezers under the metal neck of antenna 3's coaxial connector (next to antenna 2's connector) and lift straight up to disconnect it.
  24. Mac Studio 2023 Fans Replacement, Unclip the cable: passo 24, imagem 1 %32 Mac Studio 2023 Fans Replacement, Unclip the cable: passo 24, imagem 2 %32 Mac Studio 2023 Fans Replacement, Unclip the cable: passo 24, imagem 3 %32
  25. Mac Studio 2023 Fans Replacement, Remove antenna 3's screws: passo 25, imagem 1 %32 Mac Studio 2023 Fans Replacement, Remove antenna 3's screws: passo 25, imagem 2 %32
    • Use a T5 Torx screwdriver to remove the two 3.5 mm‑long screws securing antenna 3.
  26. Mac Studio 2023 Fans Replacement, Remove antenna 3: passo 26, imagem 1 %32 Mac Studio 2023 Fans Replacement, Remove antenna 3: passo 26, imagem 2 %32
    • Remove antenna 3.
  27. Mac Studio 2023 Fans Replacement, Remove the ethernet board cable cover: passo 27, imagem 1 %32 Mac Studio 2023 Fans Replacement, Remove the ethernet board cable cover: passo 27, imagem 2 %32 Mac Studio 2023 Fans Replacement, Remove the ethernet board cable cover: passo 27, imagem 3 %32
    • Use a T3 Torx screwdriver to remove the two 2 mm‑long screws securing the ethernet board cable cover.
  28. Mac Studio 2023 Fans Replacement, Disconnect the ethernet board: passo 28, imagem 1 %32 Mac Studio 2023 Fans Replacement, Disconnect the ethernet board: passo 28, imagem 2 %32
    • Be very careful not to scrape off or damage any surface mounted components during this step.
    • Use a spudger to pry up and disconnect the ethernet board cable press connector from the logic board.
    • To reconnect press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  29. Mac Studio 2023 Fans Replacement, Reposition your Mac Studio: passo 29, imagem 1 %32
    • Carefully stand up your Mac Studio so the SD card reader and two front USB-C ports are facing up.
  30. Mac Studio 2023 Fans Replacement, Remove the ethernet board cable: passo 30, imagem 1 %32 Mac Studio 2023 Fans Replacement, Remove the ethernet board cable: passo 30, imagem 2 %32 Mac Studio 2023 Fans Replacement, Remove the ethernet board cable: passo 30, imagem 3 %32
    Flexible Extension
    $6.99
    • Use a T4 Torx screwdriver to remove the two 11 mm‑long screws securing the right side of the ethernet board and its cover.
    • These screws may be hard to access. If you can't insert your screwdriver properly, use a flexible extension to avoid stripping screws or damaging the logic board.
  31. Mac Studio 2023 Fans Replacement: passo 31, imagem 1 %32 Mac Studio 2023 Fans Replacement: passo 31, imagem 2 %32 Mac Studio 2023 Fans Replacement: passo 31, imagem 3 %32
    • Insert the point of a spudger under the bottom right corner of the ethernet board press connector and lift up to disconnect it.
    • Don't pry against any surface mounted components.
    • Remove the cable.
  32. Mac Studio 2023 Fans Replacement, Remove the ethernet board screws: passo 32, imagem 1 %32 Mac Studio 2023 Fans Replacement, Remove the ethernet board screws: passo 32, imagem 2 %32
    Flexible Extension
    $6.99
    • Use a T6 Torx screwdriver to remove the two 20 mm‑long screws (with washers) securing the ethernet board.
    • Be careful not to lose the washers, as they can fall off easily.
  33. Mac Studio 2023 Fans Replacement, Remove the ethernet board: passo 33, imagem 1 %32 Mac Studio 2023 Fans Replacement, Remove the ethernet board: passo 33, imagem 2 %32
    • Lift the ethernet board out of its recess and remove it.
  34. Mac Studio 2023 Fans Replacement, Reposition your Mac Studio: passo 34, imagem 1 %32
    • Reposition your Mac Studio so the SD card reader and two front USB‑C ports are facing you.
  35. Mac Studio 2023 Fans Replacement, Remove the speaker screws: passo 35, imagem 1 %32 Mac Studio 2023 Fans Replacement, Remove the speaker screws: passo 35, imagem 2 %32 Mac Studio 2023 Fans Replacement, Remove the speaker screws: passo 35, imagem 3 %32
    • Use a T5 Torx screwdriver to remove the two 12 mm‑long screws securing the speaker.
  36. Mac Studio 2023 Fans Replacement, Reposition the speaker: passo 36, imagem 1 %32 Mac Studio 2023 Fans Replacement, Reposition the speaker: passo 36, imagem 2 %32 Mac Studio 2023 Fans Replacement, Reposition the speaker: passo 36, imagem 3 %32
  37. Mac Studio 2023 Fans Replacement, Disconnect the speaker: passo 37, imagem 1 %32 Mac Studio 2023 Fans Replacement, Disconnect the speaker: passo 37, imagem 2 %32
    • Insert the point of a spudger under the speaker connector's plastic head and carefully lift it straight up and out of its socket.
    • Don't lift on the wires themselves, or you may damage them.
    • To reconnect the cable, position the connector head over its socket and press to with the flat end of a spudger—the connector should click into place.
  38. Mac Studio 2023 Fans Replacement, Remove the speaker: passo 38, imagem 1 %32
    • Remove the speaker.
  39. Mac Studio 2023 Fans Replacement, Remove the cable cover screws: passo 39, imagem 1 %32 Mac Studio 2023 Fans Replacement, Remove the cable cover screws: passo 39, imagem 2 %32
    • Use a T3 Torx screwdriver to remove the two 2 mm‑long screws securing the I/O board cable cover.
    • Use a T8 Torx screwdriver to remove the standoff screw just to the right of the cover.
  40. Mac Studio 2023 Fans Replacement, Remove the cover: passo 40, imagem 1 %32
    • Use tweezers or your fingers to remove the I/O board cable cover.
  41. Mac Studio 2023 Fans Replacement, Disconnect the I/O board: passo 41, imagem 1 %32 Mac Studio 2023 Fans Replacement, Disconnect the I/O board: passo 41, imagem 2 %32 Mac Studio 2023 Fans Replacement, Disconnect the I/O board: passo 41, imagem 3 %32
    • Use a spudger to pry up and disconnect both of the I/O board's press connectors.
  42. Mac Studio 2023 Fans Replacement, Disconnect the power button: passo 42, imagem 1 %32 Mac Studio 2023 Fans Replacement, Disconnect the power button: passo 42, imagem 2 %32 Mac Studio 2023 Fans Replacement, Disconnect the power button: passo 42, imagem 3 %32
    • Use the point of a spudger or a clean fingernail to flip up the hinged locking flap on the power button cable ZIF connector, located on the outer edge of the I/O board.
    • Use tweezers to gently pull the cable straight out of its socket.
  43. Mac Studio 2023 Fans Replacement, Reposition your Mac Studio: passo 43, imagem 1 %32
  44. Mac Studio 2023 Fans Replacement, Remove the I/O board screws: passo 44, imagem 1 %32 Mac Studio 2023 Fans Replacement, Remove the I/O board screws: passo 44, imagem 2 %32 Mac Studio 2023 Fans Replacement, Remove the I/O board screws: passo 44, imagem 3 %32
    Flexible Extension
    $6.99
    • Use a T4 Torx screwdriver to remove the two 15.5 mm‑long screws securing the outer edge of the I/O board.
    • Use a T6 Torx screwdriver to remove the two 20 mm‑long screws securing the inner edge of the I/O board.
    • Partially tighten the four screws securing the board.
    • Lay your Mac Studio down and plug a cable into one of the ports to ensure proper fit and alignment, adjusting the port as necessary—the cable should be easy to insert and remove.
    • With the cable plugged in and the board in position, fully tighten all four screws.
    • Unplug all cables before continuing.
  45. Mac Studio 2023 Fans Replacement, Remove the I/O board: passo 45, imagem 1 %32 Mac Studio 2023 Fans Replacement, Remove the I/O board: passo 45, imagem 2 %32 Mac Studio 2023 Fans Replacement, Remove the I/O board: passo 45, imagem 3 %32
    • Lift the I/O board straight up and out of its recess to remove it.
    • During reassembly, lower the board into its recess, making sure the press connectors don't get trapped under the logic board.
  46. Mac Studio 2023 Fans Replacement, Remove the power cord port: passo 46, imagem 1 %32 Mac Studio 2023 Fans Replacement, Remove the power cord port: passo 46, imagem 2 %32
    • Lift the power cord port out of its recess and remove it.
  47. Mac Studio 2023 Fans Replacement, Reposition your Mac Studio: passo 47, imagem 1 %32
  48. Mac Studio 2023 Fans Replacement, Remove the USB‑C bracket: passo 48, imagem 1 %32 Mac Studio 2023 Fans Replacement, Remove the USB‑C bracket: passo 48, imagem 2 %32 Mac Studio 2023 Fans Replacement, Remove the USB‑C bracket: passo 48, imagem 3 %32
    Flexible Extension
    $6.99
  49. Mac Studio 2023 Fans Replacement, Remove the cable cover: passo 49, imagem 1 %32 Mac Studio 2023 Fans Replacement, Remove the cable cover: passo 49, imagem 2 %32 Mac Studio 2023 Fans Replacement, Remove the cable cover: passo 49, imagem 3 %32
    • Use a T3 Torx screwdriver to remove the two 2 mm‑long screws securing the USB‑C port cable cover.
  50. Mac Studio 2023 Fans Replacement, Disconnect the USB-C ports: passo 50, imagem 1 %32 Mac Studio 2023 Fans Replacement, Disconnect the USB-C ports: passo 50, imagem 2 %32
    • Use the point of a spudger to pry up and disconnect the USB‑C port press connector from the logic board.
    • To reconnect press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  51. Mac Studio 2023 Fans Replacement, Reposition your Mac Studio: passo 51, imagem 1 %32
    • Carefully stand up your Mac Studio so the rear ports face up.
  52. Mac Studio 2023 Fans Replacement, Remove the USB-C ports screws: passo 52, imagem 1 %32 Mac Studio 2023 Fans Replacement, Remove the USB-C ports screws: passo 52, imagem 2 %32 Mac Studio 2023 Fans Replacement, Remove the USB-C ports screws: passo 52, imagem 3 %32
    Flexible Extension
    $6.99
    • Use a T5 Torx screwdriver to remove the two 5 mm‑long screws securing the USB-C ports.
    • Partially tighten the two screws securing the top of the ports.
    • Put the USB-C bracket into place and partially tighten the screw that secures it.
    • Lay your Mac Studio down and plug a cable into each port to ensure proper fit and alignment, adjusting the ports as necessary—the cables should be easy to insert and remove.
    • With both cables plugged in and the ports in position, fully tighten all three screws.
    • Unplug any cables before continuing reassembly.
  53. Mac Studio 2023 Fans Replacement, Remove the USB-C ports: passo 53, imagem 1 %32 Mac Studio 2023 Fans Replacement, Remove the USB-C ports: passo 53, imagem 2 %32 Mac Studio 2023 Fans Replacement, Remove the USB-C ports: passo 53, imagem 3 %32
    • Use your fingers to lift the ports out of their recesses and remove them.
    • Don't try to remove an individual port. A flex cable connects them and can easily be damaged.
    • During reassembly, put the ports into their recesses, making sure the press connector stays above the logic board.
  54. Mac Studio 2023 Fans Replacement, Reposition your Mac Studio: passo 54, imagem 1 %32
  55. Mac Studio 2023 Fans Replacement, Remove the cable cover: passo 55, imagem 1 %32 Mac Studio 2023 Fans Replacement, Remove the cable cover: passo 55, imagem 2 %32 Mac Studio 2023 Fans Replacement, Remove the cable cover: passo 55, imagem 3 %32
    • Use a T3 Torx screwdriver to remove the two 2 mm‑long screws securing the back Thunderbolt 4 port cable cover.
  56. Mac Studio 2023 Fans Replacement, Disconnect the ports: passo 56, imagem 1 %32 Mac Studio 2023 Fans Replacement, Disconnect the ports: passo 56, imagem 2 %32 Mac Studio 2023 Fans Replacement, Disconnect the ports: passo 56, imagem 3 %32
    • Use a spudger to pry up and disconnect both Thunderbolt 4 cable press connectors from the logic board.
  57. Mac Studio 2023 Fans Replacement, Reposition your Mac Studio: passo 57, imagem 1 %32
    • Carefully stand up your Mac Studio so the SD card reader and front two USB-C ports face up.
  58. Mac Studio 2023 Fans Replacement, Remove the ports screws: passo 58, imagem 1 %32 Mac Studio 2023 Fans Replacement, Remove the ports screws: passo 58, imagem 2 %32 Mac Studio 2023 Fans Replacement, Remove the ports screws: passo 58, imagem 3 %32
    Flexible Extension
    $6.99
    • Use a T5 Torx screwdriver to remove the six 5 mm‑long screws securing three of the ports.
    • Use a T7 Torx screwdriver to remove the two 8 mm‑long standoff screws securing the remaining port.
    • To align and install a set of ports during reassembly:
    • Partially tighten all four screws on a set of ports.
    • Lay your Mac Studio down and plug a cable into each port to ensure proper fit and alignment, adjusting the ports as necessary—the cable should be easy to insert and remove.
    • With both cables plugged in and the port in position, fully tighten the screws.
    • Unplug all cables before continuing with reassembly.
  59. Mac Studio 2023 Fans Replacement, Remove the ports: passo 59, imagem 1 %32 Mac Studio 2023 Fans Replacement, Remove the ports: passo 59, imagem 2 %32 Mac Studio 2023 Fans Replacement, Remove the ports: passo 59, imagem 3 %32
    • Flex cables connect the two inner and two outer port pairs. Don't try to remove individual ports—you can easily damage the cables that connect them.
    • Use your fingers to lift the two inner or outer ports out of their recesses and remove them.
    • Repeat the process to remove the two other ports.
    • During reassembly, put the ports into their recesses, making sure the press connectors stay above the logic board.
  60. Mac Studio 2023 Fans Replacement, Reposition your Mac Studio: passo 60, imagem 1 %32
    • Reposition your Mac Studio so the power cord port is facing you.
  61. Mac Studio 2023 Fans Replacement, Remove the cable cover screws: passo 61, imagem 1 %32 Mac Studio 2023 Fans Replacement, Remove the cable cover screws: passo 61, imagem 2 %32 Mac Studio 2023 Fans Replacement, Remove the cable cover screws: passo 61, imagem 3 %32
    • Use a T3 Torx screwdriver to remove the four 2 mm‑long screws securing the SDXC card reader cable covers.
  62. Mac Studio 2023 Fans Replacement, Remove the cable covers: passo 62, imagem 1 %32 Mac Studio 2023 Fans Replacement, Remove the cable covers: passo 62, imagem 2 %32 Mac Studio 2023 Fans Replacement, Remove the cable covers: passo 62, imagem 3 %32
    • Use tweezers or your fingers to remove the two cable covers.
  63. Mac Studio 2023 Fans Replacement, Remove the cable: passo 63, imagem 1 %32 Mac Studio 2023 Fans Replacement, Remove the cable: passo 63, imagem 2 %32 Mac Studio 2023 Fans Replacement, Remove the cable: passo 63, imagem 3 %32
    • Use the flat end of a spudger to pry up and disconnect the card reader cable press connector from the logic board.
    • Use the point of a spudger to disconnect the cable's other press connector from the reader itself.
    • Remove the cable.
  64. Mac Studio 2023 Fans Replacement, Disconnect the card reader: passo 64, imagem 1 %32 Mac Studio 2023 Fans Replacement, Disconnect the card reader: passo 64, imagem 2 %32 Mac Studio 2023 Fans Replacement, Disconnect the card reader: passo 64, imagem 3 %32
    • Use the point of a spudger or a clean fingernail to flip up the hinged locking flap on the status indicator light cable ZIF connector, located on the right side of the card reader.
  65. Mac Studio 2023 Fans Replacement: passo 65, imagem 1 %32 Mac Studio 2023 Fans Replacement: passo 65, imagem 2 %32
    • Very light adhesive secures the cable to the side of the card reader.
    • Use tweezers to gently pull the cable away from the card reader and separate the adhesive.
  66. Mac Studio 2023 Fans Replacement, Reposition your Mac Studio: passo 66, imagem 1 %32
  67. Mac Studio 2023 Fans Replacement, Remove the SDXC card reader screws: passo 67, imagem 1 %32 Mac Studio 2023 Fans Replacement, Remove the SDXC card reader screws: passo 67, imagem 2 %32
    Flexible Extension
    $6.99
    • Use a T5 Torx screwdriver to remove the two 6 mm‑long screws securing the card reader.
  68. Mac Studio 2023 Fans Replacement, Remove the card reader: passo 68, imagem 1 %32 Mac Studio 2023 Fans Replacement, Remove the card reader: passo 68, imagem 2 %32
    • Remove the card reader.
  69. Mac Studio 2023 Fans Replacement, Reposition your Mac Studio: passo 69, imagem 1 %32
  70. Mac Studio 2023 Fans Replacement, Remove antenna 1's screws: passo 70, imagem 1 %32 Mac Studio 2023 Fans Replacement, Remove antenna 1's screws: passo 70, imagem 2 %32
    • Use a T5 Torx screwdriver to remove the two 3.5 mm‑long screws securing antenna 1.
  71. Mac Studio 2023 Fans Replacement, Secure antenna 1: passo 71, imagem 1 %32 Mac Studio 2023 Fans Replacement, Secure antenna 1: passo 71, imagem 2 %32 Mac Studio 2023 Fans Replacement, Secure antenna 1: passo 71, imagem 3 %32
    • Gently lay antenna 1 to the left of the heatsink, being careful not to strain its cable.
    • Secure antenna 1 to the logic board with a strip of painters tape.
    • Stick the tape to the heatsink screws, not directly onto the board.
  72. Mac Studio 2023 Fans Replacement, Remove the logic board assembly screws: passo 72, imagem 1 %32 Mac Studio 2023 Fans Replacement, Remove the logic board assembly screws: passo 72, imagem 2 %32
    • Use a T20 Torx screwdriver to remove the four 12 mm‑long screws securing the logic board assembly.
  73. Mac Studio 2023 Fans Replacement, Remove the logic board assembly: passo 73, imagem 1 %32 Mac Studio 2023 Fans Replacement, Remove the logic board assembly: passo 73, imagem 2 %32 Mac Studio 2023 Fans Replacement, Remove the logic board assembly: passo 73, imagem 3 %32
    • Before trying to remove the logic board assembly, note the following:
    • The assembly sits very snugly in its housing. Take your time and don't try to force it out.
    • Only grip the assembly by areas on the logic board that don't have any components. Otherwise, you may damage the board.
    • Firmly secure the housing with one hand.
    • With your free hand, carefully lift the edge of the logic board assembly with the SSD modules until you can grip the fans. Slide the assembly towards the power cord cutout as necessary to help you lift it higher.
    • Grip the board and fans together and lift the assembly out of its housing.
    • Be careful not to damage any components on the edge of the assembly when removing it.
    • During reassembly, lower the logic board assembly into its housing at a downward angle so the side with a rubber gasket is facing the power cord cutout.
  74. Mac Studio 2023 Fans Replacement, Stand up the logic board assembly: passo 74, imagem 1 %32 Mac Studio 2023 Fans Replacement, Stand up the logic board assembly: passo 74, imagem 2 %32 Mac Studio 2023 Fans Replacement, Stand up the logic board assembly: passo 74, imagem 3 %32
    • Carefully stand up the logic board assembly so you can access the two fan cable connectors on the logic board.
    • When the assembly is upright, make sure to secure it with your free hand as necessary. Otherwise, it may fall over and get damaged.
  75. Mac Studio 2023 Fans Replacement, Disconnect a fan cable: passo 75, imagem 1 %32 Mac Studio 2023 Fans Replacement, Disconnect a fan cable: passo 75, imagem 2 %32
    • Use tweezers to peel up the piece of tape covering one of the fan cable connectors.
  76. Mac Studio 2023 Fans Replacement: passo 76, imagem 1 %32 Mac Studio 2023 Fans Replacement: passo 76, imagem 2 %32 Mac Studio 2023 Fans Replacement: passo 76, imagem 3 %32
    • Use the point of a spudger or a clean fingernail to flip up the hinged locking flap on the fan cable ZIF connector.
    • Use tweezers to gently pull the cable straight out of its socket and disconnect it.
  77. Mac Studio 2023 Fans Replacement, Disconnect the other fan cable: passo 77, imagem 1 %32 Mac Studio 2023 Fans Replacement, Disconnect the other fan cable: passo 77, imagem 2 %32 Mac Studio 2023 Fans Replacement, Disconnect the other fan cable: passo 77, imagem 3 %32
    • Repeat the previous two steps to disconnect the other fan cable.
  78. Mac Studio 2023 Fans Replacement, Remove the fan screws: passo 78, imagem 1 %32 Mac Studio 2023 Fans Replacement, Remove the fan screws: passo 78, imagem 2 %32 Mac Studio 2023 Fans Replacement, Remove the fan screws: passo 78, imagem 3 %32
    • Rotate the logic board assembly so the fans are facing you.
    • Secure assembly with one hand.
    • With your free hand, use a T10 Torx screwdriver to remove the three 10 mm‑long screws securing the fans.
  79. Mac Studio 2023 Fans Replacement, Remove the fans: passo 79, imagem 1 %32 Mac Studio 2023 Fans Replacement, Remove the fans: passo 79, imagem 2 %32
    • Remove the fans.
    • During reassembly, place the fans onto their screw posts with the fan cables facing the logic board assembly.
Conclusão
Spencer Day
Membro desde: 09/14/22
153.502 Reputação
Autoria de 1.024 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.738 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 95
Ao todo: 1,146
