Ir para o conteúdo principal
Logitech Webcam Pro 9000 USB Connection Replacement
O que você precisa
    1. Logitech Webcam Pro 9000 USB Connection Replacement, Front and Back Cover: passo 1, imagem 1 %32 Logitech Webcam Pro 9000 USB Connection Replacement, Front and Back Cover: passo 1, imagem 2 %32
      • Remove the two 8 mm Phillips #0 screws on the back cover.
      • The motherboard connects the two covers together. DO NOT separate the two yet.
      • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
      Pergunte ao FixBot
      Comentar
    2. Logitech Webcam Pro 9000 USB Connection Replacement: passo 2, imagem 1 %32 Logitech Webcam Pro 9000 USB Connection Replacement: passo 2, imagem 2 %32
      • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
      • DO NOT detach the wire connecting the motherboard to the front cover.
      Pergunte ao FixBot
      Comentar
    1. Logitech Webcam Pro 9000 USB Connection Replacement, USB Connection: passo 3, imagem 1 %32 Logitech Webcam Pro 9000 USB Connection Replacement, USB Connection: passo 3, imagem 2 %32
      Ferramenta utilizada neste passo:
      • Use tweezers to grasp the white wire connector on the back of the motherboard.
      • Wiggle the connector back and forth to remove it from the socket.
      Pergunte ao FixBot
      Comentar
    2. Logitech Webcam Pro 9000 USB Connection Replacement: passo 4, imagem 1 %32 Logitech Webcam Pro 9000 USB Connection Replacement: passo 4, imagem 2 %32
      • Desolder the joint on the front of the motherboard to completely detach the USB cable.
      • Follow this link to learn how to properly solder and desolder your parts.
      Pergunte ao FixBot
      Comentar
Conclusão
Cory Davis
Membro desde: 04/14/13
236 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 12-34, Amido Spring 2013 Membro de Cal Poly, Team 12-34, Amido Spring 2013
CPSU-AMIDO-S13S12G34
4 Membros
Autoria de 16 guias
1Comentário do guia
what is the connector called
Anirudh Krishnan - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 24
Ao todo: 2,512
