Ir para o conteúdo principal
Logitech Webcam Pro 9000 Motherboard Replacement
O que você precisa
  1. Logitech Webcam Pro 9000 Motherboard Replacement, Front and Back Cover: passo 1, imagem 1 %32 Logitech Webcam Pro 9000 Motherboard Replacement, Front and Back Cover: passo 1, imagem 2 %32
    • Remove the two 8 mm Phillips #0 screws on the back cover.
    • The motherboard connects the two covers together. DO NOT separate the two yet.
    • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
    Pergunte ao FixBot
    Comentar
  2. Logitech Webcam Pro 9000 Motherboard Replacement: passo 2, imagem 1 %32 Logitech Webcam Pro 9000 Motherboard Replacement: passo 2, imagem 2 %32
    • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
    • DO NOT detach the wire connecting the motherboard to the front cover.
    Pergunte ao FixBot
    Comentar
  3. Logitech Webcam Pro 9000 Motherboard Replacement, Snapshot button: passo 3, imagem 1 %32 Logitech Webcam Pro 9000 Motherboard Replacement, Snapshot button: passo 3, imagem 2 %32 Logitech Webcam Pro 9000 Motherboard Replacement, Snapshot button: passo 3, imagem 3 %32
    • Grasp the white connector attaching the button chip wire to the motherboard.
    • Grab between the tabs and the socket.
    • Wiggle the connector back and forth to remove it from the connection box
    • Do not worry if you detach the red and black wire connection on the power button.
    Pergunte ao FixBot
    Comentar
  4. Logitech Webcam Pro 9000 Motherboard Replacement, Microphone Connection: passo 4, imagem 1 %32 Logitech Webcam Pro 9000 Motherboard Replacement, Microphone Connection: passo 4, imagem 2 %32
    • Grasp the white wire connector between the tabs and the socket.
    • Wiggle the connector back and forth to remove the front cover from the motherboard.
    Pergunte ao FixBot
    Comentar
  5. Logitech Webcam Pro 9000 Motherboard Replacement, USB Connection: passo 5, imagem 1 %32 Logitech Webcam Pro 9000 Motherboard Replacement, USB Connection: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to grasp the white wire connector on the back of the motherboard.
    • Wiggle the connector back and forth to remove it from the socket.
    Pergunte ao FixBot
    Comentar
  6. Logitech Webcam Pro 9000 Motherboard Replacement: passo 6, imagem 1 %32 Logitech Webcam Pro 9000 Motherboard Replacement: passo 6, imagem 2 %32
    • Desolder the joint on the front of the motherboard to completely detach the USB cable.
    • Follow this link to learn how to properly solder and desolder your parts.
    Pergunte ao FixBot
    Comentar
  7. Logitech Webcam Pro 9000 Motherboard Replacement, Camera: passo 7, imagem 1 %32
    • Remove the two 8mm Phillips#0 screws on the back of the motherboard.
    Pergunte ao FixBot
    Comentar
  8. Logitech Webcam Pro 9000 Motherboard Replacement: passo 8, imagem 1 %32 Logitech Webcam Pro 9000 Motherboard Replacement: passo 8, imagem 2 %32 Logitech Webcam Pro 9000 Motherboard Replacement: passo 8, imagem 3 %32
    • Remove the camera from the motherboard by desoldering the two connections as shown.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Cory Davis
Membro desde: 04/14/13
236 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 12-34, Amido Spring 2013 Membro de Cal Poly, Team 12-34, Amido Spring 2013
CPSU-AMIDO-S13S12G34
4 Membros
Autoria de 16 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 47
Ao todo: 2,597
