Ir para o conteúdo principal
Logitech Signature Slim Solar+ Feet Replacement
O que você precisa
  1. Logitech Signature Slim Solar+ Feet Replacement, Prepare your keyboard for disassembly: passo 1, imagem 1 %32 Logitech Signature Slim Solar+ Feet Replacement, Prepare your keyboard for disassembly: passo 1, imagem 2 %32
    • Slide the keyboard's power switch into the OFF position.
    • A red indicator should be visible beneath the switch.
    • Lay your keyboard down with the feet facing up on a clean work surface.
    • If your work surface may scratch the keyboard, place a soft towel under it.
    Pergunte ao FixBot
    Comentar
  2. Logitech Signature Slim Solar+ Feet Replacement: passo 2, imagem 1 %32 Logitech Signature Slim Solar+ Feet Replacement: passo 2, imagem 2 %32 Logitech Signature Slim Solar+ Feet Replacement: passo 2, imagem 3 %32
    • Insert the point of a spudger under an end of the foot.
    • Slide the spudger underneath the foot and lift until you can grip it with your fingers.
    • Peel the foot up and remove it.
    Pergunte ao FixBot
    Comentar
  3. Logitech Signature Slim Solar+ Feet Replacement, Install a replacement foot: passo 3, imagem 1 %32 Logitech Signature Slim Solar+ Feet Replacement, Install a replacement foot: passo 3, imagem 2 %32 Logitech Signature Slim Solar+ Feet Replacement, Install a replacement foot: passo 3, imagem 3 %32
    • Remove a replacement foot from its backing and firmly press it into place.
    Pergunte ao FixBot
    Comentar
Conclusão
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
Arthur Shi
Membro desde: 01/03/18
343.741 Reputação
Autoria de 915 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 34
Ao todo: 340
