Ir para o conteúdo principal
Logitech Harmony 650 Screen Replacement
O que você precisa
  1. Logitech Harmony 650 Screen Replacement, Case: passo 1, imagem 1 %32 Logitech Harmony 650 Screen Replacement, Case: passo 1, imagem 2 %32
    • Remove the battery cover by applying pressure to the indented area and pushing the cover toward the rear of the device.
    Pergunte ao FixBot
    Comentar
  2. Logitech Harmony 650 Screen Replacement: passo 2, imagem 1 %32
    • Remove the batteries using the silver pull tab.
    Pergunte ao FixBot
    Comentar
  3. Logitech Harmony 650 Screen Replacement: passo 3, imagem 1 %32
    • Using a J000 Philips head screwdriver remove the four 5mm screws around the rim of the battery chamber.
    Pergunte ao FixBot
    Comentar
  4. Logitech Harmony 650 Screen Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada neste passo:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • Remove the small plastic cover beneath the plastic LED housing by using a 3.0 flathead screwdriver and a spudger to pry it off. It is glued to the case. If you are having trouble removing it try applying some heat to loosen the glue.
    Pergunte ao FixBot
    Comentar
  5. Logitech Harmony 650 Screen Replacement: passo 5, imagem 1 %32
    • Remove the two 5mm screws located underneath the cover using a J000 Philips screwdriver bit.
    Pergunte ao FixBot
    Comentar
  6. Logitech Harmony 650 Screen Replacement: passo 6, imagem 1 %32 Logitech Harmony 650 Screen Replacement: passo 6, imagem 2 %32
    • Using a plastic opening tool, pry the case off starting from the top of the device (nearest the transmitter). There are 3 tabs along the side of the case and one at the back.
    • The top led protector plastic cover will also be freed once back is removed.
    Pergunte ao FixBot
    Comentar
  7. Logitech Harmony 650 Screen Replacement: passo 7, imagem 1 %32
    • Remove the rear cover.
    Pergunte ao FixBot
    Comentar
  8. Logitech Harmony 650 Screen Replacement, Motherboard: passo 8, imagem 1 %32 Logitech Harmony 650 Screen Replacement, Motherboard: passo 8, imagem 2 %32
    • Using a J0 screwdriver remove the three 5mm screws holding the motherboard to the front face. Two are located just below the processor in the middle of the device and the third is located at the very bottom.
    Pergunte ao FixBot
    Comentar
  9. Logitech Harmony 650 Screen Replacement: passo 9, imagem 1 %32
    • Remove the motherboard by gently pulling it away from the case.
    Pergunte ao FixBot
    Comentar
  10. Logitech Harmony 650 Screen Replacement, Screen: passo 10, imagem 1 %32 Logitech Harmony 650 Screen Replacement, Screen: passo 10, imagem 2 %32
    • Remove the black rubber gasket that surrounds the screen from the top face of the motherboard.
    • The gasket has 3 tabs along each side. The thick side of the gasket faces the top.
    Pergunte ao FixBot
    Comentar
  11. Logitech Harmony 650 Screen Replacement: passo 11, imagem 1 %32
    • Use a soldering iron to loosen the solder that connects the screen strip to the back of the motherboard. If it does not loosen easily then try using a soldering remover wick.
    • The soldering iron gets extremely hot use caution when using it around components.
    Pergunte ao FixBot
    Comentar
  12. Logitech Harmony 650 Screen Replacement: passo 12, imagem 1 %32
    Pergunte ao FixBot
    Comentar
  13. Logitech Harmony 650 Screen Replacement: passo 13, imagem 1 %32
    • Use a spudger or your hand to remove the screen from the motherboard. It is glued down.
    Pergunte ao FixBot
    Comentar
Conclusão
4 outras pessoas executaram este guia.
2Comentários do guia
Hey will beat buy honor a warrenty
antonioofficial - Responder Compartilhar
so where can i buy the screen!!!!
shortemperd Gotico - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 44
Ao todo: 3,227
