Ir para o conteúdo principal
Logitech G920 Driving Force XYAB Buttons Replacement
O que você precisa
  1. Logitech G920 Driving Force XYAB Buttons Replacement, Steering Wheel Motherboard: passo 1, imagem 1 %32
    • Use the Phillips #0 screwdriver to remove the five 9.5 mm external screws.
    • Only three of the five screws are visible from each side of the wheel due to the center unit.
    Pergunte ao FixBot
    Comentar
  2. Logitech G920 Driving Force XYAB Buttons Replacement: passo 2, imagem 1 %32
    • Using the Phillips #0 screwdriver, remove the 5 mm screws holding the bumpers in place.
    Pergunte ao FixBot
    Comentar
  3. Logitech G920 Driving Force XYAB Buttons Replacement: passo 3, imagem 1 %32 Logitech G920 Driving Force XYAB Buttons Replacement: passo 3, imagem 2 %32
    • Using the TR25 Torx Security Screwdriver, remove the six 23.8 mm screws holding the face plate together.
    • Remove the face plate from the steering wheel.
    Pergunte ao FixBot
    Comentar
  4. Logitech G920 Driving Force XYAB Buttons Replacement: passo 4, imagem 1 %32 Logitech G920 Driving Force XYAB Buttons Replacement: passo 4, imagem 2 %32
    • Remove the wheel from the main steering wheel console.
    • Ensure this is done carefully as to not damage the connection wire.
    Pergunte ao FixBot
    Comentar
  5. Logitech G920 Driving Force XYAB Buttons Replacement: passo 5, imagem 1 %32 Logitech G920 Driving Force XYAB Buttons Replacement: passo 5, imagem 2 %32
    • Remove the eight 7.5 mm screws holding the steering wheel motherboard in place using a Phillips #0 screwdriver.
    • Remove the steering wheel motherboard.
    Pergunte ao FixBot
    Comentar
  6. Logitech G920 Driving Force XYAB Buttons Replacement, XYAB Buttons: passo 6, imagem 1 %32
    • Remove the XYAB buttons from the back of the steering wheel.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 48
Ao todo: 1,227
