Ir para o conteúdo principal
Logitech G733 Charging Port Replacement
O que você precisa
  1. Logitech G733 Charging Port Replacement, Charging Port: passo 1, imagem 1 %32 Logitech G733 Charging Port Replacement, Charging Port: passo 1, imagem 2 %32
    • Gently begin to pull the left ear pad off, starting from the top.
    • Slide your finger around the edges until it releases entirely.
    Pergunte ao FixBot
    Comentar
  2. Logitech G733 Charging Port Replacement: passo 2, imagem 1 %32 Logitech G733 Charging Port Replacement: passo 2, imagem 2 %32 Logitech G733 Charging Port Replacement: passo 2, imagem 3 %32
    • Remove the four securing the speaker housing with the T4 Torx screwdriver.
    • Place these screws on the magnetic project mat so you don't lose them.
    • Lift the speaker housing away from the chassis, with care not to strain the connected speaker cable.
    Pergunte ao FixBot
    Comentar
  3. Logitech G733 Charging Port Replacement: passo 3, imagem 1 %32 Logitech G733 Charging Port Replacement: passo 3, imagem 2 %32 Logitech G733 Charging Port Replacement: passo 3, imagem 3 %32
    • Remove the screw on the bottom right-hand side of the headphone using a Phillips #00 screwdriver.
    • Use your thumb to gently pull back the tab at the upper right-hand corner of the headphone and simultaneously pull the motherboard out.
    • The scroll wheel may fly out when you pop the circuit board out. If so, just put it back in by lining up the two flat surfaces of the connectors.
    Pergunte ao FixBot
    Comentar
  4. Logitech G733 Charging Port Replacement: passo 4, imagem 1 %32 Logitech G733 Charging Port Replacement: passo 4, imagem 2 %32
    • Once the motherboard is loose, pull the wire out of its harness.
    • The wiring harness is glued, so be careful with it. It should pull out easily.
    Pergunte ao FixBot
    Comentar
  5. Logitech G733 Charging Port Replacement: passo 5, imagem 1 %32 Logitech G733 Charging Port Replacement: passo 5, imagem 2 %32 Logitech G733 Charging Port Replacement: passo 5, imagem 3 %32
    • Using the soldering iron, apply heat to three pins on one side and wiggle the port free from the melted pool of solder.
    • Repeat for the opposite side.
    • This step takes a lot of skill. Be careful not to melt the circuit board with the soldering iron, and always solder in a well-ventilated area.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
3Comentários do guia
Where did you get the spare USB Port from?
The Red Warrior - Responder Compartilhar
The closest match is TE Connectivity 2338792-1 USB TYPE C 3.1 CONN REV TOP MOUNT CH1.6
James Powers - Responder Compartilhar
2338792-1 has diffrient similar casing but diffrient pin configuration and also less pins (12), should have 14 pins. Just contacted Logitech support but they didn't want to tell me the part number. If anyone knows how to get that port, please let us know.
I want it fixed - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 9
Últimos 7 dias: 50
Últimos 30 dias: 205
Ao todo: 7,015
