Ir para o conteúdo principal
Logitech G705 Battery Replacement
O que você precisa
  1. Logitech G705 Battery Replacement, Battery: passo 1, imagem 1 %32 Logitech G705 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Remove the skate pads from the bottom of the mouse by peeling them off to access the screws.
    • If you plan on reusing these skates, you can use a hair dryer or heat gun to soften the adhesive and gently remove the skates.
    Pergunte ao FixBot
    Comentar
  2. Logitech G705 Battery Replacement: passo 2, imagem 1 %32 Logitech G705 Battery Replacement: passo 2, imagem 2 %32 Logitech G705 Battery Replacement: passo 2, imagem 3 %32
    • Use a Phillips #000 screwdriver to remove the four 5.0 mm screws securing the bottom of the mouse shell.
    • It's recommended to use a parts tray to store these small screws, so you do not lose them.
    Pergunte ao FixBot
    Comentar
  3. Logitech G705 Battery Replacement: passo 3, imagem 1 %32 Logitech G705 Battery Replacement: passo 3, imagem 2 %32 Logitech G705 Battery Replacement: passo 3, imagem 3 %32
    • Carefully pry the two halves of the mouse shell apart.
    • Be careful, as ribbon cables run along the edges.
    • Use a plastic pry tool if needed.
    Pergunte ao FixBot
    Comentar
  4. Logitech G705 Battery Replacement: passo 4, imagem 1 %32 Logitech G705 Battery Replacement: passo 4, imagem 2 %32
    • Use the point of a plastic spudger to push on alternating sides of the connector to "walk" it out of its socket.
    • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
    • If that doesn't work, use a pair of tweezers to firmly grip the sides of the battery connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
    • This step requires some force and may damage the plastic on the connector.
    Pergunte ao FixBot
    Comentar
  5. Logitech G705 Battery Replacement: passo 5, imagem 1 %32 Logitech G705 Battery Replacement: passo 5, imagem 2 %32
    • Remove the 3.0 mm PH000 screw from the black plastic bracket that secures the battery.
    • Remove the bracket.
    • The battery may come loose during this step, depending on the strength and amount of adhesive used during assembly. This is perfectly normal, and you may skip step 6 if this occurs.
    Pergunte ao FixBot
    Comentar
  6. Logitech G705 Battery Replacement: passo 6, imagem 1 %32 Logitech G705 Battery Replacement: passo 6, imagem 2 %32
    • If the battery did not come out, it may be easier to remove if the top and bottom of the mouse are separated first.
    • To separate the top and bottom of the mouse, use a spudger or a clean fingernail to flip up the locking flaps on the two ZIF connectors.
    • Use tweezers or your fingers to gently pull the ribbon cables straight out of their sockets.
    Pergunte ao FixBot
    Comentar
  7. Logitech G705 Battery Replacement: passo 7, imagem 1 %32
    • Remove the battery from the shell.
    • If the battery doesn't come out easily, use adhesive remover to loosen the adhesive and then safely remove the battery from the shell.
    • Do not use a metal pry tool or pry the battery, as doing so may damage or puncture it and cause injury.
    Pergunte ao FixBot
    Comentar
  8. Logitech G705 Battery Replacement: passo 8, imagem 1 %32
    • Place the new battery with the adhesive back in the shell.
    • If the new battery does not have adhesive already, you may use double sided tape to hold it in place.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Carmen Chavez
Membro desde: 02/23/26
81 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 95
Ao todo: 130
