Ir para o conteúdo principal
Logitech G X56 HOTAS Throttle LED Board Replacement
O que você precisa
  1. Logitech G X56 HOTAS Throttle LED Board Replacement, Label Plate: passo 1, imagem 1 %32 Logitech G X56 HOTAS Throttle LED Board Replacement, Label Plate: passo 1, imagem 2 %32
    • Remove the eight 8.6 mm long 1.5 mm hex screws from the label plate.
    Pergunte ao FixBot
    Comentar
  2. Logitech G X56 HOTAS Throttle LED Board Replacement: passo 2, imagem 1 %32
    • Use an opening tool to pry off the mode switch knob.
    Pergunte ao FixBot
    Comentar
  3. Logitech G X56 HOTAS Throttle LED Board Replacement: passo 3, imagem 1 %32 Logitech G X56 HOTAS Throttle LED Board Replacement: passo 3, imagem 2 %32 Logitech G X56 HOTAS Throttle LED Board Replacement: passo 3, imagem 3 %32
    • Remove the eight 12.5 mm long Phillips #1 screws from the underside of the label plate.
    • These screws are plastic! Be very careful when applying force.
    Pergunte ao FixBot
    Comentar
  4. Logitech G X56 HOTAS Throttle LED Board Replacement: passo 4, imagem 1 %32 Logitech G X56 HOTAS Throttle LED Board Replacement: passo 4, imagem 2 %32
    • Place the throttle right side up again, using the bottom panel as a coaster.
    • Gently pry the label plate from the body of the throttle.
    Pergunte ao FixBot
    Comentar
  5. Logitech G X56 HOTAS Throttle LED Board Replacement, Motherboard: passo 5, imagem 1 %32 Logitech G X56 HOTAS Throttle LED Board Replacement, Motherboard: passo 5, imagem 2 %32
    • Optional: Take a picture or mark each connector as you remove them for ease of reassembly.
    • Disconnect all of the motherboard connectors by pulling them straight up and out of their sockets.
    Pergunte ao FixBot
    Comentar
  6. Logitech G X56 HOTAS Throttle LED Board Replacement: passo 6, imagem 1 %32 Logitech G X56 HOTAS Throttle LED Board Replacement: passo 6, imagem 2 %32
    • Remove the four 11.6 mm-long Phillips #0 screws that secure the motherboard.
    Pergunte ao FixBot
    Comentar
  7. Logitech G X56 HOTAS Throttle LED Board Replacement: passo 7, imagem 1 %32
    • Lift the motherboard from the base plate shell, carefully making sure to keep the USB power cable unstrained.
    Pergunte ao FixBot
    Comentar
  8. Logitech G X56 HOTAS Throttle LED Board Replacement, LED Board: passo 8, imagem 1 %32 Logitech G X56 HOTAS Throttle LED Board Replacement, LED Board: passo 8, imagem 2 %32
    • Each LED Board uses the LEDs to hold it against the base plate. It also has a single cable set to the logic and power board.
    Pergunte ao FixBot
    Comentar
  9. Logitech G X56 HOTAS Throttle LED Board Replacement: passo 9, imagem 1 %32 Logitech G X56 HOTAS Throttle LED Board Replacement: passo 9, imagem 2 %32
    • Each of the LEDs needs to be removed with a soldering iron and your choice of solder wick or solder sucker.
    • Once free of the solder, the LED must be pushed through to the front.
    Pergunte ao FixBot
    Comentar
  10. Logitech G X56 HOTAS Throttle LED Board Replacement: passo 10, imagem 1 %32
    • Gently Remove the LED board.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 30
Ao todo: 331
