Introdução
This guide shows the step by step replacement of a Logitech G Pro Wireless mouse side button from disassembly to replacement to reassembly.
Required tools:
- Soldering Iron Kit
- Spudger
- Tweezers
- Phillips #00 screwdriver
SAFTEY WARNING: THIS GUIDE USES A SOLDERING IRON WHICH CAN CAUSE SEVERE BURNS OR START FIRES. IF YOU DO NOT HAVE EXPERIENCE WITH USING A SOLDERING IRON, FIND SOMEONE WHO HAS PROPER EXPERIENCE SOLDERING OR RESEARCH AND LEARN ABOUT SOLDERING IRONS AND HOW TO PROPERLY USE THEM PRIOR TO STARTING THIS GUIDE. ONLY SOLDER IN A WELL VENTILATED AREA FREE FROM HIGHLY FLAMMABLE MATERIAL. USE WITH EXTREME CAUTION.
O que você precisa
Find a stable desk or table to work on.
Create a clean work area on the surface.
Set up a mat on the work area.
Place the mouse on the work area.
Using the screwdriver, remove the two 3 mm-long Phillips #00 screws securing the middle housing assembly inside the mouse. Set the screws aside in a safe place to avoid losing them.
Using the spudger, gently pry up the middle housing assembly from the edges. Carefully lift the middle section out of the mouse body.
Using the screwdriver, remove the four 3 mm-long Phillips #00 screws securing the scroll wheel assembly to the mouse.
Using the spudger, gently lift the small ribbon cable connector from the circuit board. Carefully disconnect the ribbon cable by pulling it straight out of the connector.
Once disconnected, lift and remove the scroll wheel assembly from the mouse.
Using the screwdriver, remove the four 3mm Phillips #00 screws securing the blue side button brackets on both sides of the mouse.
Remove the nine 3 mm-long Phillips #00 screws securing the main internal frame (black plastic structure).
Remove the single 3mm Phillips #00 screw at the top of the mouse near the front end.
Using the spudger, gently insert the tip under the edge of the circuit board. Carefully pry upward to separate the board from the adhesive securing it to the frame.
Continue working along the edges until the adhesive is fully released. Once loosened, lift the circuit board assembly away from the frame.
Desolder the switch pins on the underside of the PCB.
Using the spudger, gently insert the tip underneath the side switch component. Carefully lift the edge of the switch to begin separating it from the board.
Use a second tool (such as tweezers or a flathead tool) to assist in prying the switch upward. Continue applying gentle pressure until the side switch is fully detached from the board.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
