Ir para o conteúdo principal
Liquid Damage Technique
O que você precisa
  1. Liquid Damage Technique, Top Casing: passo 1, imagem 1 %32
    • Power down and unplug the device.
    Pergunte ao FixBot
    Comentar
  2. Liquid Damage Technique: passo 2, imagem 1 %32
    Pergunte ao FixBot
    Comentar
  3. Liquid Damage Technique: passo 3, imagem 1 %32
    • Remove the two black rubber feet of the device using the screwdriver. The feet are located on the bottom towards the front.
    Pergunte ao FixBot
    Comentar
  4. Liquid Damage Technique: passo 4, imagem 1 %32
    • Once the feet are removed, two small screws will be visible. With a small screwdriver, unscrew them. Screws are phillips head, 4.35 mm in diameter, 7.88 mm in length.
    Pergunte ao FixBot
    Comentar
  5. Liquid Damage Technique: passo 5, imagem 1 %32
    • To remove the front blue panel, grip firmly and place thumbs in the two notches on top. Push thumbs forward while keeping a firm grip on bottom.
    • This may require a bit of force.
    Pergunte ao FixBot
    Comentar
  6. Liquid Damage Technique: passo 6, imagem 1 %32
    • Now slide the bottom panel forward and remove it so the top casing is isolated from the bottom casing and motherboard.
    Pergunte ao FixBot
    Comentar
  7. Liquid Damage Technique: passo 7, imagem 1 %32 Liquid Damage Technique: passo 7, imagem 2 %32
    • Unscrew the nut on the outer side of the back casing. Remove the nut and the washer from both antenna mounts.
    Pergunte ao FixBot
    Comentar
  8. Liquid Damage Technique: passo 8, imagem 1 %32 Liquid Damage Technique: passo 8, imagem 2 %32
    • From here, remove the wires and nuts connected to the back panel by pulling the nuts through the holes.
    • Now the top casing has been removed and isolated from the rest of the device. From here, you can make repairs to the top casing.
    • Once the top panel is removed the main board will still be attached to the bottom panel.
    Pergunte ao FixBot
    Comentar
  9. Liquid Damage Technique, Bottom Casing/Motherboard: passo 9, imagem 1 %32 Liquid Damage Technique, Bottom Casing/Motherboard: passo 9, imagem 2 %32
    • Unscrew the two screws that connect the motherboard to the bottom casing.
    • The motherboard and bottom casing should be completely separated at this point. This allows for replacement of the motherboard and/ or its components as well as the bottom casing.
    Pergunte ao FixBot
    Comentar
  10. Liquid Damage Technique, Liquid Damage Technique: passo 10, imagem 1 %32
    • If the spilled substance is dry use a cleaning tool such as a toothbrush with soft bristles, so you do not damage the device, to brush off as much of the foreign material as possible.
    Pergunte ao FixBot
    Comentar
  11. Liquid Damage Technique: passo 11, imagem 1 %32
    • Dry off circuit board with kitchen paper; using other types of paper products such as toilet paper will fall apart. Be sure not to rub but carefully apply pressure to dry up wet spots.
    Pergunte ao FixBot
    Comentar
  12. Liquid Damage Technique: passo 12, imagem 1 %32
    • Clean off the components to make sure the rest of the residue comes off by using a chemical gasoline or another solvent that contains one substance that evaporates quickly.
    Pergunte ao FixBot
    Comentar
Conclusão
After the device is cleaned and put back together it should work properly.
Uma outra pessoa concluiu este guia.
Derek Myers
Membro desde: 10/04/11
288 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 21-21, Maness Fall 2011 Membro de Cal Poly, Team 21-21, Maness Fall 2011
CPSU-MANESS-F11S21G21
5 Membros
Autoria de 12 guias
1Comentário do guia
I did all of this still not working it gets hot only but doesn’t turn it on.
DM MG - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 47
Ao todo: 7,760
