Introdução
If the router isn't working and it is established that the antennas are defective this is the guide for you.
Make sure the antennas are in a straight position, not bent, to remove the black casing.
Remove the casing by pulling straight up. This will make unscrewing the antenna easier.
After the repairs are made the device should working.
