Ir para o conteúdo principal
LexiBook Tablet One Speaker Replacement
O que você precisa
    1. LexiBook Tablet One Speaker Replacement, Speaker: passo 1, imagem 1 %32 LexiBook Tablet One Speaker Replacement, Speaker: passo 1, imagem 2 %32 LexiBook Tablet One Speaker Replacement, Speaker: passo 1, imagem 3 %32
      • Insert the blue plastic opening tool where the case has a seam. Move side to side until you hear a clip pop. Move around the edge of the case until all clips are separated. The clips are 1.5 in. apart within the case.
      Pergunte ao FixBot
      Comentar
    2. LexiBook Tablet One Speaker Replacement: passo 2, imagem 1 %32 LexiBook Tablet One Speaker Replacement: passo 2, imagem 2 %32
      • After successfully separating the casing insert a plastic spudger between the case and the speaker. Carefully pry the speaker out. Once the speaker is removed set the back casing aside.
      Pergunte ao FixBot
      Comentar
    3. LexiBook Tablet One Speaker Replacement: passo 3, imagem 1 %32
      • Using a soldering gun, apply heat where the speaker wires meet the motherboard. Heat the solder around both the black and red wires until they easily slide away.
      • Be careful not to heat the motherboard too long so to avoid damaging other components. Also, care to avoid liquefying the solder on any near by components.
      • How to Solder is IFixIt's official guide to use a soldering gun.
      Pergunte ao FixBot
      Comentar
Conclusão
Jordan
Membro desde: 03/11/15
650 Reputação
Autoria de 4 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 30
Ao todo: 425
