Ir para o conteúdo principal
Lenovo Yoga 6 13ALC6 Battery Replacement
O que você precisa
  1. Lenovo Yoga 6 13ALC6 Battery Replacement, Unfasten the lower case: passo 1, imagem 1 %32 Lenovo Yoga 6 13ALC6 Battery Replacement, Unfasten the lower case: passo 1, imagem 2 %32
    • Use a T5 Torx screwdriver to remove the six 7.2 mm screws securing the lower case.
  2. Lenovo Yoga 6 13ALC6 Battery Replacement, Insert the opening pick: passo 2, imagem 1 %32 Lenovo Yoga 6 13ALC6 Battery Replacement, Insert the opening pick: passo 2, imagem 2 %32
    • Insert an opening pick between the lower case and the chassis at a hinge corner.
    • Pry up with the pick to release the clips securing the lower case.
    • Repeat the process on the other hinge corner.
  3. Lenovo Yoga 6 13ALC6 Battery Replacement, Release the clips: passo 3, imagem 1 %32 Lenovo Yoga 6 13ALC6 Battery Replacement, Release the clips: passo 3, imagem 2 %32 Lenovo Yoga 6 13ALC6 Battery Replacement, Release the clips: passo 3, imagem 3 %32
    • Slide the pick along the right edge to release the clips securing the lower case.
  4. Lenovo Yoga 6 13ALC6 Battery Replacement, Release the remaining clips: passo 4, imagem 1 %32 Lenovo Yoga 6 13ALC6 Battery Replacement, Release the remaining clips: passo 4, imagem 2 %32 Lenovo Yoga 6 13ALC6 Battery Replacement, Release the remaining clips: passo 4, imagem 3 %32
    • Continue sliding the opening pick along the front and left edges to release the remaining clips.
  5. Lenovo Yoga 6 13ALC6 Battery Replacement: passo 5, imagem 1 %32 Lenovo Yoga 6 13ALC6 Battery Replacement: passo 5, imagem 2 %32 Lenovo Yoga 6 13ALC6 Battery Replacement: passo 5, imagem 3 %32
    • Insert the pick on the hinge edge and slide along the entire edge to release all of the clips.
  6. Lenovo Yoga 6 13ALC6 Battery Replacement: passo 6, imagem 1 %32 Lenovo Yoga 6 13ALC6 Battery Replacement: passo 6, imagem 2 %32 Lenovo Yoga 6 13ALC6 Battery Replacement: passo 6, imagem 3 %32
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  7. Lenovo Yoga 6 13ALC6 Battery Replacement, Disconnect the battery: passo 7, imagem 1 %32 Lenovo Yoga 6 13ALC6 Battery Replacement, Disconnect the battery: passo 7, imagem 2 %32 Lenovo Yoga 6 13ALC6 Battery Replacement, Disconnect the battery: passo 7, imagem 3 %32
    • Use the pointed end of a spudger to push each side of the battery connector until it comes out of the socket.
  8. Lenovo Yoga 6 13ALC6 Battery Replacement, Unfasten the battery: passo 8, imagem 1 %32 Lenovo Yoga 6 13ALC6 Battery Replacement, Unfasten the battery: passo 8, imagem 2 %32
    • Use a Phillips screwdriver to remove the five 4.2 mm-long screws securing the battery.
  9. Lenovo Yoga 6 13ALC6 Battery Replacement, Remove the battery: passo 9, imagem 1 %32 Lenovo Yoga 6 13ALC6 Battery Replacement, Remove the battery: passo 9, imagem 2 %32 Lenovo Yoga 6 13ALC6 Battery Replacement, Remove the battery: passo 9, imagem 3 %32
    • Lift the battery straight out of its recess and remove it.
Conclusão
For optimal performance, calibrate your newly installed battery after completing this guide.
Alex Diaz-Kokaisl
Membro desde: 01/16/22
125.037 Reputação
Autoria de 582 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 136
Autoria de 17.430 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 35
Últimos 30 dias: 152
Duração total: 2,051
