Ir para o conteúdo principal
Lenovo Yoga 3 Pro SSD Replacement
O que você precisa
  1. Lenovo Yoga 3 Pro SSD Replacement, Battery: passo 1, imagem 1 %32
    • Before opening your laptop, make sure it is powered off.
    • Remove the ten 3.3 mm screws from the base cover using a T5 Torx screwdriver.
  2. Lenovo Yoga 3 Pro SSD Replacement: passo 2, imagem 1 %32
    • Slide the plastic opening tool between the base cover and the frame to pry open the computer.
    • Slowly go around the entire perimeter of the computer until all edges are loose.
    • Make sure the plastic opening tool doesn't go too far into the device.
  3. Lenovo Yoga 3 Pro SSD Replacement: passo 3, imagem 1 %32
    • Remove the panel and place it in a safe location.
  4. Lenovo Yoga 3 Pro SSD Replacement: passo 4, imagem 1 %32
    • Remove the six 3.5 mm screws surrounding the battery using a Phillips 00 screwdriver.
    Hi
    I have a Lenovo Yoga 3 pro - 1370
    I take off the SSD without remove the battery. Is this a problem?
    TKS
    Stanley
    Stanleyslaw Castro - Responder
  5. Lenovo Yoga 3 Pro SSD Replacement: passo 5, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using either tweezers or your fingers, disconnect the black battery cable by pinching either side of the connector and pulling towards the battery.
  6. Lenovo Yoga 3 Pro SSD Replacement: passo 6, imagem 1 %32
    • Carefully lift and remove the battery.
    If you have the right tools, this is really straightforward to do. Took me about 10 minutes. The instructions are very accurate.
    Kevin Lawless - Responder
    Regarding the battery connector, the male plug is attached to the battery wiring (you will know what I mean when you look at it) and the female socket is attached to the logic board. There are small ridges on either side of the plug that can be grasped with fingernails to gently tease the plug out of the socket.
    Ron Westfall - Responder
  7. Lenovo Yoga 3 Pro SSD Replacement, SSD: passo 7, imagem 1 %32
    • Remove the 1.5 mm screw using the Philips 00 screwdriver.
  8. Lenovo Yoga 3 Pro SSD Replacement: passo 8, imagem 1 %32 Lenovo Yoga 3 Pro SSD Replacement: passo 8, imagem 2 %32
    • Use the plastic opening tool to remove the hard drive/SSD.
Conclusão
8 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 12-17, Maness Fall 2015 Membro de Cal Poly, Team 12-17, Maness Fall 2015
CPSU-MANESS-F15S12G17
Membros da 4
Autoria de 15 guias
5 comentários
Thank you. This looks much easier than I imagined that it would.
jlh105 - Responder
Why do you remove the battery? Can't you just unhook the battery cable?
tombillet - Responder
You dont have to remove the battery at all to access the SSD
Tunza -
I don't think this guide is 100% accurate, in that the Yoga 3 Pro (mine anyway) ONLY supports SATA3, and NOT NVME(PCIe), for the SSD interface.
As such, if you order, and try to install the Crucial P5 drive (after imaging the old drive to the P5), it will NOT recognize it, in the BIOS, because it can't bootstrap (or in any way, really) the drive.
Maybe there were multiple motherboards, with different chipsets, for the Yoga3 Pro, I have no idea, on this part, but I know the one we have is definitely limited, to SATA3.
@CPSU-MANESS-F15S12G17 (I hope this tags the team, I couldn't figure out how to tag Federico+LopezCasildo, directly, so I'm tagging "the team"), you might want to review this, and adjust, accordingly (there are plenty of SATA3 drives that can/will work, with this system).
pgrey - Responder
Thanks for noting this! I think you're right—I'll update the guide!
Arthur Shi -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 87
Duração total: 22,222
