Ir para o conteúdo principal
Lenovo Thinkpad T450 Internal Battery Replacement
O que você precisa
  1. Lenovo Thinkpad T450 Internal Battery Replacement, External Battery: passo 1, imagem 1 %32 Lenovo Thinkpad T450 Internal Battery Replacement, External Battery: passo 1, imagem 2 %32 Lenovo Thinkpad T450 Internal Battery Replacement, External Battery: passo 1, imagem 3 %32
    • Using your hands, slide the two locking tabs away from each other to release the battery.
    • Slide the battery up and out of the device.
  2. Lenovo Thinkpad T450 Internal Battery Replacement, Back Cover: passo 2, imagem 1 %32
    • Using the JIS #00 screwdriver, unscrew seven screws from the back cover.
    • These screws are not removable and will remain in the back cover.
    • Use the JIS #00 screwdriver to remove the single 2.8 mm screw from the back cover.
  3. Lenovo Thinkpad T450 Internal Battery Replacement: passo 3, imagem 1 %32 Lenovo Thinkpad T450 Internal Battery Replacement: passo 3, imagem 2 %32 Lenovo Thinkpad T450 Internal Battery Replacement: passo 3, imagem 3 %32
    • Insert a plastic opening tool into the edges of the laptop and work your way around the edges to pry off the back cover from the device.
    • Remove the back cover from the device.
  4. Lenovo Thinkpad T450 Internal Battery Replacement, Internal Battery: passo 4, imagem 1 %32 Lenovo Thinkpad T450 Internal Battery Replacement, Internal Battery: passo 4, imagem 2 %32
    • Using the JIS #00 screwdriver, remove the three 2.8 mm screws.
  5. Lenovo Thinkpad T450 Internal Battery Replacement: passo 5, imagem 1 %32 Lenovo Thinkpad T450 Internal Battery Replacement: passo 5, imagem 2 %32
    • Disconnect the battery cable from the motherboard using the plastic opening tool.
  6. Lenovo Thinkpad T450 Internal Battery Replacement: passo 6, imagem 1 %32
    • Lift up and remove the battery from the device.
Conclusão
For optimal performance, after completing this guide, calibrate your newly installed battery.
Justin Ogihara
Membro desde: 09/18/17
27.236 Reputação
Autoria de 52 guias
Equipe
EDU Team Membro de EDU Team
Staff
Membros da 7
Autoria de 637 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 30
Últimos 30 dias: 156
Duração total: 4,389
