Ir para o conteúdo principal
Lenovo ThinkPad X395 Battery Replacement
O que você precisa
  1. Lenovo ThinkPad X395 Battery Replacement, Loosen the back screws: passo 1, imagem 1 %32 Lenovo ThinkPad X395 Battery Replacement, Loosen the back screws: passo 1, imagem 2 %32
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Phillips #1 screwdriver to fully loosen the five screws on the back cover.
    • These are captive screws—they won't come out after being loosened.
  2. Lenovo ThinkPad X395 Battery Replacement, Release the clips: passo 2, imagem 1 %32 Lenovo ThinkPad X395 Battery Replacement, Release the clips: passo 2, imagem 2 %32
    • Orient your laptop so that the screen's silver hinges are closest to you.
    • Insert an opening pick between the back cover and the device body near a hinge corner.
    • Pry upward to release the retaining clips. Listen for a loud click when each clip releases.
  3. Lenovo ThinkPad X395 Battery Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad X395 Battery Replacement: passo 3, imagem 2 %32
    • Insert the opening pick between the back cover and the device body at the other hinge corner.
    • Pry upward on the cover to release additional clips.
  4. Lenovo ThinkPad X395 Battery Replacement, Remove the back cover: passo 4, imagem 1 %32 Lenovo ThinkPad X395 Battery Replacement, Remove the back cover: passo 4, imagem 2 %32 Lenovo ThinkPad X395 Battery Replacement, Remove the back cover: passo 4, imagem 3 %32
    • Lift and remove the cover up from the laptop, starting with the edge nearest to you.
    • Shift the cover side to side if the center clip feels stuck.
    • The cover will hinge open before completely separating from the rest of the laptop.
  5. Lenovo ThinkPad X395 Battery Replacement, Disconnect the battery cable: passo 5, imagem 1 %32 Lenovo ThinkPad X395 Battery Replacement, Disconnect the battery cable: passo 5, imagem 2 %32
    • Grab the battery pull-tab on the head of the connector.
    • Pull the connector out of its socket in the direction of the cable.
  6. Lenovo ThinkPad X395 Battery Replacement, Unfasten the battery: passo 6, imagem 1 %32
    • Use your Phillips screwdriver to remove the four 5.3 mm-long screws securing the battery.
  7. Lenovo ThinkPad X395 Battery Replacement, Remove the battery: passo 7, imagem 1 %32 Lenovo ThinkPad X395 Battery Replacement, Remove the battery: passo 7, imagem 2 %32
    • Remove the battery from its recess.
Conclusão
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo ThinkPad answers community for help.
Clay Eickemeyer
Membro desde: 09/19/22
67.166 Reputação
Autoria de 453 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 136
Autoria de 17.392 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 47
Últimos 30 dias: 165
Duração total: 2,244
