Ir para o conteúdo principal
Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement
O que você precisa
  1. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Back Cover: passo 1, imagem 1 %32 Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Back Cover: passo 1, imagem 2 %32 Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Back Cover: passo 1, imagem 3 %32
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Speakers: passo 2, imagem 1 %32
    • Use a Phillips #00 head screwdriver to remove the four 4 mm screws above the battery.
  3. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement: passo 3, imagem 1 %32
    • Lift the speaker modules on either side of the battery out of its pegs, and unwind the cable from the front of the battery.
    • Set the speaker modules out of the way.
  4. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Battery: passo 4, imagem 1 %32 Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Battery: passo 4, imagem 2 %32 Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Battery: passo 4, imagem 3 %32
    • Use tweezers to peel the plastic cover off the connector.
    • Use a spudger or your fingernail to pry up the battery straight up from the motherboard.
  5. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement: passo 5, imagem 1 %32
    • Lift the battery out of the frame and remove it from the device.
Conclusão
4 outras pessoas executaram este guia.
Beckham Richmond
Membro desde: 02/10/20
462 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S7-G3, Regan Winter 2020 Membro de Cal Poly, Team S7-G3, Regan Winter 2020
CPSU-REGAN-W20S7G3
Membros da 4
Autoria de 8 guias
2 comentários
Could I use the same battery for my X1 Extreme Gen 1 laptop? Thanks.
Huy Tran - Responder
Thank you so much for this illustration on how to take off the battery. I was like already stuck at just the screws not coming off. This helped immensely.
Rafael Dolfe - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 10
Últimos 7 dias: 59
Últimos 30 dias: 261
Duração total: 10,218
