Ir para o conteúdo principal
Lenovo ThinkPad X1 Carbon 7th Gen Battery Replacement
O que você precisa
  1. Lenovo ThinkPad X1 Carbon 7th Gen Battery Replacement, Back cover removal: passo 1, imagem 1 %32 Lenovo ThinkPad X1 Carbon 7th Gen Battery Replacement, Back cover removal: passo 1, imagem 2 %32
    • Use a Phillips #1 screwdriver to loosen the five captive screws securing the back cover.
  2. Lenovo ThinkPad X1 Carbon 7th Gen Battery Replacement, Insert an opening pick: passo 2, imagem 1 %32 Lenovo ThinkPad X1 Carbon 7th Gen Battery Replacement, Insert an opening pick: passo 2, imagem 2 %32 Lenovo ThinkPad X1 Carbon 7th Gen Battery Replacement, Insert an opening pick: passo 2, imagem 3 %32
    • Insert an opening pick at a 45˚ angle between the back cover and frame near the rear middle screw.
    • Pry up on the pick to release the clips securing the back cover to the frame.
    • You will hear several clicks while prying up.
  3. Lenovo ThinkPad X1 Carbon 7th Gen Battery Replacement, Remove the back cover: passo 3, imagem 1 %32 Lenovo ThinkPad X1 Carbon 7th Gen Battery Replacement, Remove the back cover: passo 3, imagem 2 %32 Lenovo ThinkPad X1 Carbon 7th Gen Battery Replacement, Remove the back cover: passo 3, imagem 3 %32
    • Lift the back cover up and remove it from the chassis.
    • You will hear several clicks while lifting up.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  4. Lenovo ThinkPad X1 Carbon 7th Gen Battery Replacement, Battery disconnect: passo 4, imagem 1 %32 Lenovo ThinkPad X1 Carbon 7th Gen Battery Replacement, Battery disconnect: passo 4, imagem 2 %32 Lenovo ThinkPad X1 Carbon 7th Gen Battery Replacement, Battery disconnect: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use tweezers or your fingers to peel back the plastic shield covering the battery connector.
  5. Lenovo ThinkPad X1 Carbon 7th Gen Battery Replacement, Disconnect the battery: passo 5, imagem 1 %32 Lenovo ThinkPad X1 Carbon 7th Gen Battery Replacement, Disconnect the battery: passo 5, imagem 2 %32 Lenovo ThinkPad X1 Carbon 7th Gen Battery Replacement, Disconnect the battery: passo 5, imagem 3 %32
    • Use the flat end of a spudger to pry up on and disconnect the battery cable.
  6. Lenovo ThinkPad X1 Carbon 7th Gen Battery Replacement, Unfasten the battery: passo 6, imagem 1 %32 Lenovo ThinkPad X1 Carbon 7th Gen Battery Replacement, Unfasten the battery: passo 6, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the six 4.9 mm-long screws securing the battery.
  7. Lenovo ThinkPad X1 Carbon 7th Gen Battery Replacement, Remove the battery: passo 7, imagem 1 %32 Lenovo ThinkPad X1 Carbon 7th Gen Battery Replacement, Remove the battery: passo 7, imagem 2 %32 Lenovo ThinkPad X1 Carbon 7th Gen Battery Replacement, Remove the battery: passo 7, imagem 3 %32
    • Lift the battery straight out of its recess and remove it.
Conclusão
For optimal performance, calibrate your newly installed battery after completing this guide.
20 outras pessoas executaram este guia.
Alex Diaz-Kokaisl
Membro desde: 01/16/22
162.615 Reputação
Autoria de 769 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 118
Autoria de 19.465 guias
10 comentários
Thank you for the post! My laptop battery is totally dead, not charging at all at 0%, so I cannot disable the built-in battery. Since it immediately dies if unplugged, the built-in battery is automatically enabled while it’s turned on and plugged. Can I just let it unplugged and proceed?
Soo J - Responder
You should still be able to access BIOS with the laptop plugged into its charger to disable the battery before unplugging it and removing it. However, if that does not work, just be careful not to bridge any of the pins the battery connects to on the motherboard and everything should still be fine.
Jaxon Haws -
The X1 g.7 has a known bug where internal battery stops working (won’t charge, or says battery not detected in windows). I have personally solved this problem on 4-5 laptops by disconnecting the battery (follow this guide until step 4) and then plugging it back in after ten seconds. In 90% of the cases this has solved the problem without battery replacement.
cesepan - Responder
Yeah it's a hardware connection issue at least in my case. A light kick to the back of the laptop also works usually.
The Tomatoes -
Thanks! This has been very helpful. Just followed the steps until removing the battery connector and putting it back. Issue sorted!
kj_only1 -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 28
Últimos 7 dias: 189
Últimos 30 dias: 762
Duração total: 62,035
