Ir para o conteúdo principal
Lenovo ThinkPad T560 Keyboard Replacement
O que você precisa
  1. Lenovo ThinkPad T560 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32 Lenovo ThinkPad T560 Keyboard Replacement, Keyboard: passo 1, imagem 2 %32 Lenovo ThinkPad T560 Keyboard Replacement, Keyboard: passo 1, imagem 3 %32
    • Before you begin this guide, make sure to disable the internal battery, power down the device and disconnect from any external power sources.
    • Using the spudger, slide the keyboard up towards the display at the notches created for this purpose.
    Pergunte ao FixBot
    Comentar
  2. Lenovo ThinkPad T560 Keyboard Replacement: passo 2, imagem 1 %32
    • Using the Phillips #0 screwdriver, remove the six 3.5 mm screws that secure the keyboard to the laptop.
    Pergunte ao FixBot
    Comentar
  3. Lenovo ThinkPad T560 Keyboard Replacement: passo 3, imagem 1 %32 Lenovo ThinkPad T560 Keyboard Replacement: passo 3, imagem 2 %32
    • Using the spudger, push the keyboard toward the display and then slide it back out of the connector at top of the keyboard to remove.
    • Don't pull on the keyboard as it is attached by two ZIF connectors underneath.
    • Flip the keyboard over to expose the keyboard's connections to the motherboard and touchpad.
    Pergunte ao FixBot
    Comentar
  4. Lenovo ThinkPad T560 Keyboard Replacement: passo 4, imagem 1 %32 Lenovo ThinkPad T560 Keyboard Replacement: passo 4, imagem 2 %32
    • Using the spudger, open the latches securing the keyboard's connections to the motherboard and touchpad.
    • Remove the keyboard.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
Clemson, Team 1-3, Hunter Spring 2022 Membro de Clemson, Team 1-3, Hunter Spring 2022
CLEM-HUNTER-S22S1G3
5 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 64
Ao todo: 3,135
