Ir para o conteúdo principal
Lenovo ThinkPad T560 Fan Replacement
O que você precisa
  1. Lenovo ThinkPad T560 Fan Replacement, Back Panel: passo 1, imagem 1 %32
    • Before you begin this guide, make sure to disable the internal battery, power down the device and disconnect from any external power sources.
    • The external battery should be removed prior to back panel disassembly however this device doesn't have one so we aren't able to show the process.
    • Using the Phillips #0 screwdriver, remove the eight 7 mm screws holding the back panel to the T560.
    Pergunte ao FixBot
    Comentar
  2. Lenovo ThinkPad T560 Fan Replacement: passo 2, imagem 1 %32
    • Use the iFixit opening tool to pry the back panel off your T560.
    • Work your way around the perimeter of the device to undo the clips and detach the back panel.
    Pergunte ao FixBot
    Comentar
  3. Lenovo ThinkPad T560 Fan Replacement, Battery: passo 3, imagem 1 %32 Lenovo ThinkPad T560 Fan Replacement, Battery: passo 3, imagem 2 %32
    • Disconnect the battery connector from the motherboard by pulling it out of the port.
    Pergunte ao FixBot
    Comentar
  4. Lenovo ThinkPad T560 Fan Replacement: passo 4, imagem 1 %32
    • Using the Phillips #0 screwdriver, remove the five 3.5 mm screws securing the battery.
    • Remove the battery.
    Pergunte ao FixBot
    Comentar
  5. Lenovo ThinkPad T560 Fan Replacement, Fan: passo 5, imagem 1 %32 Lenovo ThinkPad T560 Fan Replacement, Fan: passo 5, imagem 2 %32 Lenovo ThinkPad T560 Fan Replacement, Fan: passo 5, imagem 3 %32
    • Using the iFixit opening tool, unlatch the power button's connection to the motherboard.
    • Remove the ribbon cable from the connector.
    Pergunte ao FixBot
    Comentar
  6. Lenovo ThinkPad T560 Fan Replacement: passo 6, imagem 1 %32
    • Unplug the fan from the motherboard.
    Pergunte ao FixBot
    Comentar
  7. Lenovo ThinkPad T560 Fan Replacement: passo 7, imagem 1 %32
    • Using the Phillips #0 screwdriver, remove the four 3.5 mm screws securing the heatsink.
    Pergunte ao FixBot
    Comentar
  8. Lenovo ThinkPad T560 Fan Replacement: passo 8, imagem 1 %32
    • Using the Phillips #0 screwdriver, unscrew the 3.5mm screw securing the fan to the case.
    • Remove the fan and conjoined heatsink.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
Clemson, Team 1-3, Hunter Spring 2022 Membro de Clemson, Team 1-3, Hunter Spring 2022
CLEM-HUNTER-S22S1G3
5 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 43
Ao todo: 1,705
