Ir para o conteúdo principal
Lenovo ThinkPad T480 Wi-Fi Card Replacement
O que você precisa
  1. Lenovo ThinkPad T480 Wi-Fi Card Replacement, External Battery: passo 1, imagem 1 %32 Lenovo ThinkPad T480 Wi-Fi Card Replacement, External Battery: passo 1, imagem 2 %32
    • Disable the battery, power down, and unplug your device before you begin.
    • Flip the laptop over so the bottom of the device is showing.
  2. Lenovo ThinkPad T480 Wi-Fi Card Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad T480 Wi-Fi Card Replacement: passo 2, imagem 2 %32 Lenovo ThinkPad T480 Wi-Fi Card Replacement: passo 2, imagem 3 %32
    • Using your fingers, slide the lock on each side of the battery to the unlocked position.
    • Remove the battery from the slot.
  3. Lenovo ThinkPad T480 Wi-Fi Card Replacement, Back Cover: passo 3, imagem 1 %32 Lenovo ThinkPad T480 Wi-Fi Card Replacement, Back Cover: passo 3, imagem 2 %32
    • Using the Phillips #1 screwdriver, loosen the six captive screws.
  4. Lenovo ThinkPad T480 Wi-Fi Card Replacement: passo 4, imagem 1 %32 Lenovo ThinkPad T480 Wi-Fi Card Replacement: passo 4, imagem 2 %32 Lenovo ThinkPad T480 Wi-Fi Card Replacement: passo 4, imagem 3 %32
    • Insert the blue plastic opening tool into the space between the lower case and the chassis.
    • Slide the opening tool around the perimeter of the case to release the clips holding the case and the chassis together.
    • If it feels like the battery well portion of the back cover isn't loose, these clips may be holding the cover to the laptop. Use your opening tool to pry the clips loose and try removing the cover again.
    • Remove the back case.
    I found a tough spudger (or even better a plectrum) is best here as the clips, although easy to separate, hold the case firmly leaving a tight gap which a soft spudger may fail to enter.
    Benjamin Kinsey - Responder
    Hi Benjamin, thanks for the tip!
    Sarah Westberg -
    You also have to pry the near the battery. I experienced that you can't pry the front side.
    Minko Kelko - Responder
    I used a credit card to pry the clips loose, it worked great. Added 2nd RAM stick easily.
    NFR Computers - Responder
  5. Lenovo ThinkPad T480 Wi-Fi Card Replacement, Internal Battery: passo 5, imagem 1 %32 Lenovo ThinkPad T480 Wi-Fi Card Replacement, Internal Battery: passo 5, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the two 4.6 mm screws that secure the internal battery to the frame.
  6. Lenovo ThinkPad T480 Wi-Fi Card Replacement: passo 6, imagem 1 %32 Lenovo ThinkPad T480 Wi-Fi Card Replacement: passo 6, imagem 2 %32 Lenovo ThinkPad T480 Wi-Fi Card Replacement: passo 6, imagem 3 %32
    • Use the spudger to slide the battery socket connector parallel to the motherboard and out of its socket on the motherboard.
  7. Lenovo ThinkPad T480 Wi-Fi Card Replacement: passo 7, imagem 1 %32 Lenovo ThinkPad T480 Wi-Fi Card Replacement: passo 7, imagem 2 %32
    • Lift the battery straight out of its recess and remove it.
    • If the battery is difficult to remove from the recess, use a nylon spudger to gently lift it on one edge, making it easier to grasp and remove by hand.
    • To prevent damage or potential fire, do not bend or flex the battery. Only use a plastic spudger and avoid any sharp tools that could puncture the battery.
    DO NOT wedge out the battery - T480 has two screws that hold down a plastic battery tray which easily lifts out after the two frame screws are removed. Wedging out will ruin the battery and could damage the cell and cause a fire.
    Poseidon219 - Responder
    The guide says to remove those two screws. They are "lifting" with the wedge. Probably more of a way to promote their tools than out of necessity, but idk
    Lorenzo Serrano - Responder
    You lift the internal battery first from the top, and then the bottom.
    This is because there are 2 "clips" on the bottom that the battery uses to slide into the chassis.
    Tai Lam - Responder
  8. Lenovo ThinkPad T480 Wi-Fi Card Replacement, Wi-Fi Card: passo 8, imagem 1 %32
    • Using the Phillips #1 screwdriver, remove the single 3.6 mm screw at the top of the Wi-Fi card attaching it to the motherboard.
  9. Lenovo ThinkPad T480 Wi-Fi Card Replacement: passo 9, imagem 1 %32 Lenovo ThinkPad T480 Wi-Fi Card Replacement: passo 9, imagem 2 %32
    • Insert the point of a spudger under one of the antenna cables close to the connector. Pry straight up to disconnect the cable off of the Wi-Fi card.
    • Be careful as you pry the cables off of the Wi-Fi card as they are fragile and easily damaged.
  10. Lenovo ThinkPad T480 Wi-Fi Card Replacement: passo 10, imagem 1 %32 Lenovo ThinkPad T480 Wi-Fi Card Replacement: passo 10, imagem 2 %32
    • Slide the Wi-Fi card out from the slot to remove it from the board.
Conclusão
4 outras pessoas executaram este guia.
Sarah Westberg
Membro desde: 03/11/19
29.674 Reputação
Autoria de 71 guias
Equipe
iFixit Membro de iFixit
Staff
118 Membros
Autoria de 19.631 guias
1Comentário do guia
Great guide! Everyone make sure to reconnect the black cable to terminal 2 (on the left) and white to t1 (to the right).
Comentar
Visualizações:
Últimas 24 horas: 12
Últimos 7 dias: 53
Últimos 30 dias: 254
Ao todo: 7,636
