Ir para o conteúdo principal
Lenovo ThinkPad T480 RAM Replacement
O que você precisa
  1. Lenovo ThinkPad T480 RAM Replacement, External Battery: passo 1, imagem 1 %32 Lenovo ThinkPad T480 RAM Replacement, External Battery: passo 1, imagem 2 %32
    • Disable the battery, power down, and unplug your device before you begin.
    • Flip the laptop over so the bottom of the device is showing.
  2. Lenovo ThinkPad T480 RAM Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad T480 RAM Replacement: passo 2, imagem 2 %32 Lenovo ThinkPad T480 RAM Replacement: passo 2, imagem 3 %32
    • Using your fingers, slide the lock on each side of the battery to the unlocked position.
    • Remove the battery from the slot.
  3. Lenovo ThinkPad T480 RAM Replacement, Back Cover: passo 3, imagem 1 %32 Lenovo ThinkPad T480 RAM Replacement, Back Cover: passo 3, imagem 2 %32
    • Using the Phillips #1 screwdriver, loosen the six captive screws.
  4. Lenovo ThinkPad T480 RAM Replacement: passo 4, imagem 1 %32 Lenovo ThinkPad T480 RAM Replacement: passo 4, imagem 2 %32 Lenovo ThinkPad T480 RAM Replacement: passo 4, imagem 3 %32
    • Insert the blue plastic opening tool into the space between the lower case and the chassis.
    • Slide the opening tool around the perimeter of the case to release the clips holding the case and the chassis together.
    • If it feels like the battery well portion of the back cover isn't loose, these clips may be holding the cover to the laptop. Use your opening tool to pry the clips loose and try removing the cover again.
    • Remove the back case.
    I found a tough spudger (or even better a plectrum) is best here as the clips, although easy to separate, hold the case firmly leaving a tight gap which a soft spudger may fail to enter.
    Benjamin Kinsey - Responder
    Hi Benjamin, thanks for the tip!
    Sarah Westberg -
    You also have to pry the near the battery. I experienced that you can't pry the front side.
    Minko Kelko - Responder
    I used a credit card to pry the clips loose, it worked great. Added 2nd RAM stick easily.
    NFR Computers - Responder
  5. Lenovo ThinkPad T480 RAM Replacement, Internal Battery: passo 5, imagem 1 %32 Lenovo ThinkPad T480 RAM Replacement, Internal Battery: passo 5, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the two 4.6 mm screws that secure the internal battery to the frame.
  6. Lenovo ThinkPad T480 RAM Replacement: passo 6, imagem 1 %32 Lenovo ThinkPad T480 RAM Replacement: passo 6, imagem 2 %32 Lenovo ThinkPad T480 RAM Replacement: passo 6, imagem 3 %32
    • Use the spudger to slide the battery socket connector parallel to the motherboard and out of its socket on the motherboard.
  7. Lenovo ThinkPad T480 RAM Replacement: passo 7, imagem 1 %32 Lenovo ThinkPad T480 RAM Replacement: passo 7, imagem 2 %32
    • Lift the battery straight out of its recess and remove it.
    • If the battery is difficult to remove from the recess, use a nylon spudger to gently lift it on one edge, making it easier to grasp and remove by hand.
    • To prevent damage or potential fire, do not bend or flex the battery. Only use a plastic spudger and avoid any sharp tools that could puncture the battery.
    DO NOT wedge out the battery - T480 has two screws that hold down a plastic battery tray which easily lifts out after the two frame screws are removed. Wedging out will ruin the battery and could damage the cell and cause a fire.
    Poseidon219 - Responder
    The guide says to remove those two screws. They are "lifting" with the wedge. Probably more of a way to promote their tools than out of necessity, but idk
    Lorenzo Serrano - Responder
    You lift the internal battery first from the top, and then the bottom.
    This is because there are 2 "clips" on the bottom that the battery uses to slide into the chassis.
    Tai Lam - Responder
  8. Lenovo ThinkPad T480 RAM Replacement, RAM: passo 8, imagem 1 %32 Lenovo ThinkPad T480 RAM Replacement, RAM: passo 8, imagem 2 %32 Lenovo ThinkPad T480 RAM Replacement, RAM: passo 8, imagem 3 %32
    • Pull the black plastic sheet back to reveal the RAM stick.
    • Using your fingers, pull the metal arms (located on both sides of the RAM stick) slightly away from it .
    • The RAM will pop up by a few millimeters.
    • Remove it at an angle and not straight up so you don't damage the socket.
  9. Lenovo ThinkPad T480 RAM Replacement: passo 9, imagem 1 %32 Lenovo ThinkPad T480 RAM Replacement: passo 9, imagem 2 %32
    • Slide the RAM stick out from the memory module slot.
    • Repeat for the RAM stick located below. This computer did not have RAM in the slot below however.
Conclusão
15 outras pessoas executaram este guia.
Sarah Westberg
Membro desde: 03/11/19
29.686 Reputação
Autoria de 71 guias
Equipe
iFixit Membro de iFixit
Staff
118 Membros
Autoria de 19.637 guias
8Comentários do guia
Nice one Sarah! Straightforward install of additional RAM following these instructions - one thing I noted is that I don't have an internal battery, it's just a placeholder, so I left it out, thanks again ;)
Raj - Responder
Hi @raj61669 I know your comment is over a year old but thank you for the feedback! I'm glad the guide was helpful : )
Sarah Westberg -
Great guide! Just update T480 from original 8GB to 32GB!
One thing to point out is that on my T480, after loosening all of the screws there was an area of the back cover the was in the middle, in the rear next to the battery compartment that required an uncomfortable amount of pull to ultimately disconnect and remove the back cover from the chassis of the T480... So be careful but forceful! Thanks! :-)
MyFixIt - Responder
Hi @myfixit63593 Sorry it took me so long to reply. Thanks for your feedback and the tip! This is an important warning for other fixers : )
Sarah Westberg -
Kann ich den RAM auch mit mehr MHZ ersetzen? Ich habe eine Lenovo Thinkpad mit aktuell 2x 8GB 800MHZ. Von einem anderem Laptop habe ich 2x8GB mit 3200MHZ ausgebaut. Was passiert, wenn ich diesen in den Thinkpad einbaue,, weil vorher nur 800MHZ drin waren?
deichkind - Responder
Hi, @deichkind,
I consulted a co-worker and they provided this information: RAM speeds are backwards compatible within the same generation (DDR1-DDR4). If the 8GB 800MHZ was DDR3 and the replacement 3200 MHZ is DDR3, the new RAM will run at the fastest speed the motherboard can support. But, if the 800MHZ was DDR2 and the replacement is DDR3, it may not work.
I hope this helps. If it doesn't answer your question, please let me know and I can direct it to our answers forum. Also, I apologize that this is in English but I don't speak German.
Sarah Westberg -
Da solltest du denke ich nachschauen ob das Motherboard das unterstützt. Der Unterschied zwischen 800 und 3200 scheint mir aber sehr groß, insofern bezweifele ich dass das funktionieren wird...
Kev -
Please avoid attempting anything that makes you uncomfortable or seems incompatible with your device. I gathered this information from the Lenovo Forum and discussions on the subreddit r/thinkpad, leading me to believe that this could be a viable option for the T480.
Sarah Westberg -
Comentar
Visualizações:
Últimas 24 horas: 25
Últimos 7 dias: 177
Últimos 30 dias: 854
Ao todo: 37,408
