Ir para o conteúdo principal
Lenovo ThinkPad T470 TrackPad Replacement
O que você precisa
  1. Lenovo ThinkPad T470 TrackPad Replacement, External Battery: passo 1, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement, External Battery: passo 1, imagem 2 %32 Lenovo ThinkPad T470 TrackPad Replacement, External Battery: passo 1, imagem 3 %32
    • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
    • Place the laptop so that the bottom is facing upwards.
    • Slide the latch on the left side of the battery to the left until it clicks in place.
  2. Lenovo ThinkPad T470 TrackPad Replacement: passo 2, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 2, imagem 2 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 2, imagem 3 %32
    • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
    • Use your other hand to slide the battery towards the back of the laptop.
    • Lift the battery up and away from the laptop.
  3. Lenovo ThinkPad T470 TrackPad Replacement, Internal Components: passo 3, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement, Internal Components: passo 3, imagem 2 %32
    • Use a Phillips #1 screwdriver to loosen the six captive screws on the bottom cover of the laptop.
  4. Lenovo ThinkPad T470 TrackPad Replacement: passo 4, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 4, imagem 2 %32
    • Place the laptop so that the top is facing upwards.
    • Open the lid of the laptop.
  5. Lenovo ThinkPad T470 TrackPad Replacement: passo 5, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 5, imagem 2 %32
    • Place your fingers on the bottom edge of the keyboard.
    • Use a small amount of pressure to push the keyboard towards the screen.
  6. Lenovo ThinkPad T470 TrackPad Replacement: passo 6, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 6, imagem 2 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 6, imagem 3 %32
    • Grab the bottom edge of the keyboard with your hands, and flip the keyboard upside-down, so it rests on the bottom of the laptop.
    • Potential for device damage: The keyboard is still attached to the rest of the laptop, so be gentle when flipping it over.
  7. Lenovo ThinkPad T470 TrackPad Replacement: passo 7, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 7, imagem 2 %32
    • Use the flat end of a spudger to flip up the locking flaps securing each of the two ribbon cables.
  8. Lenovo ThinkPad T470 TrackPad Replacement: passo 8, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 8, imagem 2 %32
    • Use your hands to lift the keyboard up and away from the laptop.
  9. Lenovo ThinkPad T470 TrackPad Replacement: passo 9, imagem 1 %32
    • Close the laptop's lid and flip the laptop over so that the bottom is facing upwards.
  10. Lenovo ThinkPad T470 TrackPad Replacement: passo 10, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 10, imagem 2 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 10, imagem 3 %32
    • Use your hands to pull up on the back cover and release the plastic clips starting on the bottom side of the battery compartment.
    • Potential for device damage: Be sure to detach the plastic clips in this area first. You risk cracking the bottom cover if you attempt to detach it from around the edges of the laptop first.
    • Use your hands to pull up on the right side of the bottom cover to release the plastic clips.
    • Use your hands to pull up on the left side of the bottom cover to release the plastic clips.
  11. Lenovo ThinkPad T470 TrackPad Replacement: passo 11, imagem 1 %32
    • Remove the bottom cover from the laptop.
  12. Lenovo ThinkPad T470 TrackPad Replacement: passo 12, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 12, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove two 5 mm screws from the internal battery.
  13. Lenovo ThinkPad T470 TrackPad Replacement: passo 13, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 13, imagem 2 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 13, imagem 3 %32
    • Use your hands to lift the battery up and away from the laptop.
  14. Lenovo ThinkPad T470 TrackPad Replacement: passo 14, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 14, imagem 2 %32
    • Use your fingers to flip the black flap covering the top stick of RAM down.
  15. Lenovo ThinkPad T470 TrackPad Replacement: passo 15, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 15, imagem 2 %32
    • Use your thumbs to push the metal clips on either end of the RAM outwards.
    • The RAM will pop up by a few millimeters.
  16. Lenovo ThinkPad T470 TrackPad Replacement: passo 16, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 16, imagem 2 %32
    • Use your fingers to lift the RAM out of its socket and away from the laptop to remove it.
  17. Lenovo ThinkPad T470 TrackPad Replacement: passo 17, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 17, imagem 2 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 17, imagem 3 %32
    • Use your fingers to flip the black flap covering the bottom stick of RAM up.
  18. Lenovo ThinkPad T470 TrackPad Replacement: passo 18, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 18, imagem 2 %32
  19. Lenovo ThinkPad T470 TrackPad Replacement: passo 19, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 19, imagem 2 %32
    • Use the flat end of a spudger to flip up the metal clip securing the SSD connector to the motherboard.
  20. Lenovo ThinkPad T470 TrackPad Replacement: passo 20, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 20, imagem 2 %32
    • Use the flat end of a spudger to separate the connector from its socket.
  21. Lenovo ThinkPad T470 TrackPad Replacement: passo 21, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 21, imagem 2 %32
    • Grab the tab on the left side of the hard drive, and pull up to remove it from the laptop.
  22. Lenovo ThinkPad T470 TrackPad Replacement: passo 22, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 22, imagem 2 %32
    • Use a finger to press the black flap covering the Wi-Fi card down.
  23. Lenovo ThinkPad T470 TrackPad Replacement: passo 23, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 23, imagem 2 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 23, imagem 3 %32
    • Use the flat end of a spudger to disconnect the two coaxial wires from the Wi-Fi card.
    • When reassembling, reattach the gray wire on the left and the black wire on the right.
  24. Lenovo ThinkPad T470 TrackPad Replacement: passo 24, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 24, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the single 4 mm screw from the Wi-Fi card.
  25. Lenovo ThinkPad T470 TrackPad Replacement: passo 25, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 25, imagem 2 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 25, imagem 3 %32
    • Use your fingers to lift the Wi-Fi card up and out of its slot.
    • This laptop does not include a WWAN card, but if yours does, follow the same procedure as Steps 9-12 to remove it.
  26. Lenovo ThinkPad T470 TrackPad Replacement: passo 26, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 26, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use a pair of blunt nose tweezers to pull the white connector out of its socket.
  27. Lenovo ThinkPad T470 TrackPad Replacement: passo 27, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 27, imagem 2 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 27, imagem 3 %32
    • Grab the wire attached to the coin cell battery, and lift it up and out of the laptop.
  28. Lenovo ThinkPad T470 TrackPad Replacement: passo 28, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 28, imagem 2 %32
    • Use a pair of blunt nose tweezers to pull the white fan connector out of its socket on the motherboard.
  29. Lenovo ThinkPad T470 TrackPad Replacement: passo 29, imagem 1 %32
    • Use a Phillips #1 screwdriver to loosen the first pair of captive screws on the fan and heat sink assembly in a crosswise pattern.
    • Use a Phillips #1 screwdriver to loosen the second pair of captive screws on the fan and heat sink assembly in a crosswise pattern.
  30. Lenovo ThinkPad T470 TrackPad Replacement: passo 30, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 30, imagem 2 %32
    • Use your hand to pull the fan and heat sink assembly up and away from the laptop.
    • Clean the thermal paste from the heatsink and CPU and reapply fresh paste before reassembling.
  31. Lenovo ThinkPad T470 TrackPad Replacement, Motherboard: passo 31, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement, Motherboard: passo 31, imagem 2 %32
    • Use the flat end of a spudger to flip up the metal clip securing the LCD cable to the motherboard.
  32. Lenovo ThinkPad T470 TrackPad Replacement: passo 32, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 32, imagem 2 %32
    • Use the flat end of a spudger to disconnect the LCD cable from its socket on the motherboard.
  33. Lenovo ThinkPad T470 TrackPad Replacement: passo 33, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 33, imagem 2 %32
    • Use the flat end of a spudger to flip the power button cable's black tab up.
  34. Lenovo ThinkPad T470 TrackPad Replacement: passo 34, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 34, imagem 2 %32
    • Use the flat end of a spudger to slide the power button cable out of its connector on the motherboard.
  35. Lenovo ThinkPad T470 TrackPad Replacement: passo 35, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 35, imagem 2 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 35, imagem 3 %32
    • Use your fingers to detach the red and blue antenna cables from their slots.
  36. Lenovo ThinkPad T470 TrackPad Replacement: passo 36, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 36, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the two 4 mm screws from the USB bracket.
  37. Lenovo ThinkPad T470 TrackPad Replacement: passo 37, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 37, imagem 2 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 37, imagem 3 %32
    • Use your fingers to lift the USB bracket up and away from the laptop.
  38. Lenovo ThinkPad T470 TrackPad Replacement: passo 38, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 38, imagem 2 %32
    Comprar
    • Use a pair of blunt nose tweezers to disconnect the DC-in cable from its socket on the motherboard.
  39. Lenovo ThinkPad T470 TrackPad Replacement: passo 39, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 39, imagem 2 %32
    • Use the flat end of a spudger to flip up the metal bracket securing the camera cable to the motherboard.
  40. Lenovo ThinkPad T470 TrackPad Replacement: passo 40, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 40, imagem 2 %32
    • Use the flat end of a spudger to disconnect the camera cable from its socket on the motherboard.
  41. Lenovo ThinkPad T470 TrackPad Replacement: passo 41, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 41, imagem 2 %32
    • Use a pair of blunt nose tweezers to disconnect the speaker cable from its socket on the motherboard.
  42. Lenovo ThinkPad T470 TrackPad Replacement: passo 42, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 42, imagem 2 %32
    • Use the flat end of a spudger to flip up the black tabs on the trackpad and fingerprint reader cables.
  43. Lenovo ThinkPad T470 TrackPad Replacement: passo 43, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 43, imagem 2 %32
    • Use a pair of blunt nose tweezers to slide the trackpad and fingerprint reader cables out of their connectors on the motherboard.
  44. Lenovo ThinkPad T470 TrackPad Replacement: passo 44, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 44, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the three 4 mm screws from the I/O bracket.
  45. Lenovo ThinkPad T470 TrackPad Replacement: passo 45, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 45, imagem 2 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 45, imagem 3 %32
    • Use your fingers to slide the I/O bracket to the left.
    • Lift the I/O bracket up and away from the laptop.
  46. Lenovo ThinkPad T470 TrackPad Replacement: passo 46, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 46, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the six 4 mm screws from the motherboard.
    • This laptop does not have an NFC cable, but if yours does, use the flat end of a spudger to flip up the tab and slide the cable out of its connector.
  47. Lenovo ThinkPad T470 TrackPad Replacement: passo 47, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 47, imagem 2 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 47, imagem 3 %32
    • Use both hands to lift the motherboard up and away from the laptop.
  48. Lenovo ThinkPad T470 TrackPad Replacement, Trackpad: passo 48, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement, Trackpad: passo 48, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the four 4 mm screws.
  49. Lenovo ThinkPad T470 TrackPad Replacement: passo 49, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 49, imagem 2 %32
    • Peel up the white ribbon cable.
    • Potential for device damage: The cable may be attached to the laptop with strong adhesive, so be cautious not to tear it.
  50. Lenovo ThinkPad T470 TrackPad Replacement: passo 50, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 50, imagem 2 %32
    • Use both hands to lift up the bottom frame of the laptop a few centimeters.
  51. Lenovo ThinkPad T470 TrackPad Replacement: passo 51, imagem 1 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 51, imagem 2 %32 Lenovo ThinkPad T470 TrackPad Replacement: passo 51, imagem 3 %32
    • Hold the frame up with one hand.
    • Use your other hand to slide the trackpad toward you and away from the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Kristen Gismondi
Membro desde: 11/12/14
82.689 Reputação
Autoria de 202 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 136
Autoria de 17.420 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 26
Últimos 30 dias: 86
Duração total: 3,396
