Ir para o conteúdo principal
Lenovo ThinkPad P50 Display Replacement
O que você precisa
  1. Lenovo ThinkPad P50 Display Replacement, Battery: passo 1, imagem 1 %32 Lenovo ThinkPad P50 Display Replacement, Battery: passo 1, imagem 2 %32
    • Slide the battery latch to the left to unlock it and remove the battery.
    Pergunte ao FixBot
    Comentar
  2. Lenovo ThinkPad P50 Display Replacement, Bottom case screws: passo 2, imagem 1 %32
    • Loosen the six 12.6 mm captive screws that secure the lower case with the Phillips #00 screwdriver.
    • The screws will not come all the way out; do not attempt to remove them from the case.
    • Pull up the notch with your fingernail or a spudger.
    Pergunte ao FixBot
    Comentar
  3. Lenovo ThinkPad P50 Display Replacement, Bottom case: passo 3, imagem 1 %32 Lenovo ThinkPad P50 Display Replacement, Bottom case: passo 3, imagem 2 %32
    • Lift the lower case up and off of the chassis.
    Pergunte ao FixBot
    Comentar
  4. Lenovo ThinkPad P50 Display Replacement, Display: passo 4, imagem 1 %32 Lenovo ThinkPad P50 Display Replacement, Display: passo 4, imagem 2 %32
    • Use an iFixit opening pick to carefully remove the plastic bezel from the front of the display.
    • There are clips beneath the trim that need to be carefully detached.
    • Avoid using metal tools, as they can damage the plastic components.
    Pergunte ao FixBot
    Comentar
  5. Lenovo ThinkPad P50 Display Replacement: passo 5, imagem 1 %32
    • Remove the four 2.5 mm screws located along the corners with a Phillips #00 screwdriver.
    Pergunte ao FixBot
    Comentar
  6. Lenovo ThinkPad P50 Display Replacement: passo 6, imagem 1 %32 Lenovo ThinkPad P50 Display Replacement: passo 6, imagem 2 %32 Lenovo ThinkPad P50 Display Replacement: passo 6, imagem 3 %32
    • Carefully tilt the screen forward and lay it face down on the keyboard, making sure not to strain or damage the cable still attached to it.
    • Display (sometimes called eDP cables in laptops) and camera cable connectors often have a small metal buckle running around the socket, locking them in place. The connectors are typically wide and may have tape attached to the buckle.
    • Gently push the tip of a spudger under the metal buckle to unclip it, then swing it over the socket.
    • Hold the buckle and cable together and gently pull the connector straight out of its socket.
    Pergunte ao FixBot
    Comentar
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 16
Últimos 30 dias: 109
Ao todo: 613
