Introdução
Use this guide to replace the battery in your Lenovo Legion 5 17ACH6H Laptop.
For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
O que você precisa
Use a Phillips #1 screwdriver to remove the following ten screws securing the back cover to the frame:
Six 12.8 mm PH1 screws
Four 4.6 mm PH1 screws
Insert the rounded edge of an opening pick between the back cover and the frame in the lower right corner.
Angle the pick to about 45˚.
Insert the edge of an opening pick between the back cover and the frame on the right edge.
Angle the pick to about 30˚ and slide down the left edge to release the clips.
Repeat the same procedure on the left edge to release the clips.
Slide the opening pick between the frame and the plastic vents on the right side near the USB-A port.
Rotate the pick so that it is positioned on top of the plastic vents.
Slide the opening pick between the frame and the plastic vents on the left side near the USB-C port.
Push the pick between the frame and plastic vents.
Slide the pick along the top edge of the plastic vents to release the clips.
Use the pointed end of a spudger to push each side of the battery connector to loosen it.
Use a Phillips #0 screwdriver to remove the six 5 mm-long screws securing the battery.
For optimal performance, calibrate your newly installed battery after completing this guide.
