Ir para o conteúdo principal
Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement
O que você precisa
  1. Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement, Back Panel: passo 1, imagem 1 %32 Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement, Back Panel: passo 1, imagem 2 %32
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement: passo 2, imagem 1 %32 Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement: passo 2, imagem 2 %32 Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement: passo 2, imagem 3 %32
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement: passo 3, imagem 1 %32 Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement: passo 3, imagem 2 %32
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement, Battery Disconnect: passo 4, imagem 1 %32 Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement, Battery Disconnect: passo 4, imagem 2 %32 Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement, Battery Disconnect: passo 4, imagem 3 %32
    • Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard.
    • Be sure to apply even pressure across the wires and connector to not damage the battery cable.
  5. Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement, M.2 SSD: passo 5, imagem 1 %32 Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement, M.2 SSD: passo 5, imagem 2 %32 Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement, M.2 SSD: passo 5, imagem 3 %32
    • Remove the single 2.9 mm screw holding down the solid state drive with a Phillips #0 screwdriver.
    • The SSD will rise to rest at an angle once the screw is removed.
  6. Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement: passo 6, imagem 1 %32 Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement: passo 6, imagem 2 %32 Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement: passo 6, imagem 3 %32
    • Pull the solid state drive out of its port to the right at a similar angle to which it rests.
    • Remove the SSD from the device.
Conclusão
Uma outra pessoa concluiu este guia.
Austin Blakely
Membro desde: 03/11/19
22.274 Reputação
Autoria de 53 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.767 guias
1Comentário do guia
Very informative, the pictures were most helpful.
IDK if you've got a guide detailing the drive cloning process or not but that would put the icing on the cake.
Thank you
FaQue Microsoft - Responder
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 45
Últimos 30 dias: 143
Ao todo: 7,704
