Ir para o conteúdo principal
Lenovo IdeaPad Flex 5-1570 Heatsink Replacement
O que você precisa
  1. Lenovo IdeaPad Flex 5-1570 Heatsink Replacement, Back Panel: passo 1, imagem 1 %32 Lenovo IdeaPad Flex 5-1570 Heatsink Replacement, Back Panel: passo 1, imagem 2 %32
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: passo 2, imagem 1 %32 Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: passo 2, imagem 2 %32 Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: passo 2, imagem 3 %32
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: passo 3, imagem 1 %32 Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: passo 3, imagem 2 %32
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5-1570 Heatsink Replacement, Battery: passo 4, imagem 1 %32 Lenovo IdeaPad Flex 5-1570 Heatsink Replacement, Battery: passo 4, imagem 2 %32
    • Remove the two 5 mm Phillips #00 screws that secure the battery in place.
  5. Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: passo 5, imagem 1 %32 Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: passo 5, imagem 2 %32 Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: passo 5, imagem 3 %32
    • Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard.
    • Be sure to apply even pressure across the wires and connector to not damage the battery cable.
    • Remove the battery from the device.
  6. Lenovo IdeaPad Flex 5-1570 Heatsink Replacement, Fan: passo 6, imagem 1 %32
    • Remove the two 5 mm Phillips #00 screws that secure the fan in place.
  7. Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: passo 7, imagem 1 %32
    • Using your hands, remove the wire that is wrapped around the base of the fan.
  8. Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: passo 8, imagem 1 %32 Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: passo 8, imagem 2 %32
    • Disconnect the wire holding the fan and the motherboard together.
    • Remove the fan from the device.
  9. Lenovo IdeaPad Flex 5-1570 Heatsink Replacement, Heatsink: passo 9, imagem 1 %32
  10. Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: passo 10, imagem 1 %32 Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: passo 10, imagem 2 %32
    • Carefully remove the heatsink from the device.
    • During reassembly, don't forget to apply thermal paste onto the heatsink. For proper technique on thermal paste application, please visit the How to Apply Thermal Paste guide.
Conclusão
Don’t forget to reapply thermal paste during reassembly. For proper technique on thermal paste application, please visit the How to Apply Thermal Paste guide.
Uma outra pessoa concluiu este guia.
Justin Ogihara
Membro desde: 09/18/17
27.259 Reputação
Autoria de 52 guias
Equipe
EDU Team Membro de EDU Team
Staff
Membros da 7
Autoria de 642 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 18
Últimos 30 dias: 49
Duração total: 811
