Ir para o conteúdo principal
Lenovo Essential G580 Optical Drive Replacement
O que você precisa
  1. Lenovo Essential G580 Optical Drive Replacement, Optical Drive: passo 1, imagem 1 %32
    • Locate the removable portion on the bottom of the laptop.
    Pergunte ao FixBot
    Comentar
  2. Lenovo Essential G580 Optical Drive Replacement: passo 2, imagem 1 %32
    • Using a size 00 Phillips Head screwdriver, remove the two M2.5x4 screws connecting the removable plate to the frame of the computer.
    Pergunte ao FixBot
    Comentar
  3. Lenovo Essential G580 Optical Drive Replacement: passo 3, imagem 1 %32
    • Using both hands, slide the plate off of the back of the laptop.
    Pergunte ao FixBot
    Comentar
  4. Lenovo Essential G580 Optical Drive Replacement: passo 4, imagem 1 %32
    • Remove the M2.5x6 screw that fastens the optical drive to the laptop.
    Pergunte ao FixBot
    Comentar
  5. Lenovo Essential G580 Optical Drive Replacement: passo 5, imagem 1 %32
    • Using a spudger, push against the portion of the drive that was fastened. Be sure to push the drive outward as though it was opening. This completely ejects the device and prepares the laptop for a replacement part.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Tyler Robbins
Membro desde: 03/02/17
182 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S13-G3, Cagle Spring 2017 Membro de USF Tampa, Team S13-G3, Cagle Spring 2017
USFT-CAGLE-S17S13G3
4 Membros
1 Guia de autoria
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 48
Ao todo: 2,556
