Ir para o conteúdo principal
Lenovo 100s Chromebook-11IBY Battery Replacement
O que você precisa
  1. Lenovo 100s Chromebook-11IBY Battery Replacement, Battery: passo 1, imagem 1 %32
    • Ensure your device is turned off and unplugged.
  2. Lenovo 100s Chromebook-11IBY Battery Replacement: passo 2, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove the nine 6mm screws from the larger back plate.
  3. Lenovo 100s Chromebook-11IBY Battery Replacement: passo 3, imagem 1 %32 Lenovo 100s Chromebook-11IBY Battery Replacement: passo 3, imagem 2 %32
    • Turn your laptop back over, open it, and use the plastic opening tool on the recessed notch to gently pry each side and lift the keyboard plate up.
    • Be careful not to pull keyboard plate out immediately because cables are attached.
  4. Lenovo 100s Chromebook-11IBY Battery Replacement: passo 4, imagem 1 %32 Lenovo 100s Chromebook-11IBY Battery Replacement: passo 4, imagem 2 %32
    • Unlock the keyboard ZIF connector to release the keyboard flex cable.
    • To unlock a ZIF connector, use an opening tool or your fingernail to flip up the small, hinged locking flap.
    • Unlock the touchpad ZIF connector to release the touchpad flex cable.
    • Carefully pull both flex cables out of the ZIF connectors.
    • Remove the keyboard plate up and place it to the side.
  5. Lenovo 100s Chromebook-11IBY Battery Replacement: passo 5, imagem 1 %32
    • Unplug the battery cable by pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  6. Lenovo 100s Chromebook-11IBY Battery Replacement: passo 6, imagem 1 %32
    • Use the Phillips #0 screwdriver to remove the three 6mm screws from the battery.
  7. Lenovo 100s Chromebook-11IBY Battery Replacement: passo 7, imagem 1 %32
    • Remove the battery.
Conclusão
For optimal performance, after completing this guide, calibrate your newly installed battery.
Milton Perez
Membro desde: 03/09/17
630 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S7-G2, Cagle Spring 2017 Membro de USF Tampa, Team S7-G2, Cagle Spring 2017
USFT-CAGLE-S17S7G2
1 Membro
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 16
Duração total: 2,376
