Introdução
Replacing the ribbon cable.
O que você precisa
Turn the closed phone so that the back panel is facing you.
Press down and forward firmly on the gray tab in the middle of the phone.
Use a soldering iron to desolder the solder joint on the front of the motherboard.
Turn phone so that the back side is facing you.
Press blue button and remove top half using Spudger.
