Ir para o conteúdo principal
LG Refrigerator Freezer Ice Maker Replacement
O que você precisa
  1. LG Refrigerator Freezer Ice Maker Replacement, Unplug your refrigerator: passo 1, imagem 1 %32
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
    Pergunte ao FixBot
    Comentar
  2. LG Refrigerator Freezer Ice Maker Replacement, Open the freezer door: passo 2, imagem 1 %32 LG Refrigerator Freezer Ice Maker Replacement, Open the freezer door: passo 2, imagem 2 %32
    • Pull open the freezer door fully.
    Pergunte ao FixBot
    Comentar
  3. LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer and bin: passo 3, imagem 1 %32 LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer and bin: passo 3, imagem 2 %32 LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer and bin: passo 3, imagem 3 %32
    • Lift and remove the upper pull-out drawer.
    • Lift and remove the main drawer bin.
    Pergunte ao FixBot
    Comentar
  4. LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer rail covers: passo 4, imagem 1 %32 LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer rail covers: passo 4, imagem 2 %32 LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer rail covers: passo 4, imagem 3 %32
    • Use your finger or a flat-blade screwdriver to depress the two locking tabs on the right drawer rail cover.
    • Lift the cover off of the rail and remove it.
    • Repeat this procedure for the left drawer rail cover.
    Pergunte ao FixBot
    Comentar
  5. LG Refrigerator Freezer Ice Maker Replacement, Reassembly notes: passo 5, imagem 1 %32 LG Refrigerator Freezer Ice Maker Replacement, Reassembly notes: passo 5, imagem 2 %32
    • The drawer rail covers can be tricky to reinstall. Follow these steps to reinstall them:
    • Hold the drawer rail cover flush against the side of the drawer rail.
    • You should feel the locking tabs protruding.
    • Push the rail cover straight downward to install. It should click into place.
    Pergunte ao FixBot
    Comentar
  6. LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer: passo 6, imagem 1 %32 LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer: passo 6, imagem 2 %32
    • Use a Phillips screwdriver to remove the screw securing the drawer to each of the drawer slides.
    Pergunte ao FixBot
    Comentar
  7. LG Refrigerator Freezer Ice Maker Replacement: passo 7, imagem 1 %32 LG Refrigerator Freezer Ice Maker Replacement: passo 7, imagem 2 %32 LG Refrigerator Freezer Ice Maker Replacement: passo 7, imagem 3 %32
    • Lift the front of the drawer up.
    • Pull the drawer toward you to release the drawer from the drawer slides.
    • Remove the freezer drawer.
    Pergunte ao FixBot
    Comentar
  8. LG Refrigerator Freezer Ice Maker Replacement, Release the ice maker: passo 8, imagem 1 %32
    • Use a Phillips screwdriver to remove the screws securing the ice maker to the top of the freezer compartment.
    Pergunte ao FixBot
    Comentar
  9. LG Refrigerator Freezer Ice Maker Replacement: passo 9, imagem 1 %32 LG Refrigerator Freezer Ice Maker Replacement: passo 9, imagem 2 %32 LG Refrigerator Freezer Ice Maker Replacement: passo 9, imagem 3 %32
    • Insert a flat-blade screwdriver into the slot located on the right edge of the ice maker.
    • Pry outward with the screwdriver to release the locking tab securing the ice maker to the fridge.
    • When the tab releases, pull the right front corner of the ice maker down.
    Pergunte ao FixBot
    Comentar
  10. LG Refrigerator Freezer Ice Maker Replacement: passo 10, imagem 1 %32
    • Repeat the previous operation on the left side of the ice maker to release it.
    Pergunte ao FixBot
    Comentar
  11. LG Refrigerator Freezer Ice Maker Replacement: passo 11, imagem 1 %32 LG Refrigerator Freezer Ice Maker Replacement: passo 11, imagem 2 %32 LG Refrigerator Freezer Ice Maker Replacement: passo 11, imagem 3 %32
    • Grasp the front edge of the ice maker and pull it towards you.
    • Lower the ice maker.
    Pergunte ao FixBot
    Comentar
  12. LG Refrigerator Freezer Ice Maker Replacement, Disconnect and remove the ice maker: passo 12, imagem 1 %32 LG Refrigerator Freezer Ice Maker Replacement, Disconnect and remove the ice maker: passo 12, imagem 2 %32 LG Refrigerator Freezer Ice Maker Replacement, Disconnect and remove the ice maker: passo 12, imagem 3 %32
    • Squeeze the ice maker connector to release it and pull it straight out to disconnect it.
    • Remove the ice maker.
    Pergunte ao FixBot
    Comentar
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
4 outras pessoas executaram este guia.
Bill Gilbert
Membro desde: 06/30/22
39.929 Reputação
Autoria de 261 guias
Equipe
iFixit Membro de iFixit
Staff
122 Membros
Autoria de 26.593 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 21
Últimos 7 dias: 190
Últimos 30 dias: 576
Ao todo: 8,986
