Ir para o conteúdo principal
LG Refrigerator Control Board Replacement
O que você precisa
  1. LG Refrigerator Control Board Replacement, Unplug your refrigerator: passo 1, imagem 1 %32
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
    Pergunte ao FixBot
    Comentar
  2. LG Refrigerator Control Board Replacement, Unfasten the control board cover: passo 2, imagem 1 %32
    • Use a Phillips screwdriver to remove the screws securing the control board cover.
    Pergunte ao FixBot
    Comentar
  3. LG Refrigerator Control Board Replacement, Remove the control board cover: passo 3, imagem 1 %32 LG Refrigerator Control Board Replacement, Remove the control board cover: passo 3, imagem 2 %32 LG Refrigerator Control Board Replacement, Remove the control board cover: passo 3, imagem 3 %32
    • Tilt the top edge of the cover toward you and lift it off.
    Pergunte ao FixBot
    Comentar
  4. LG Refrigerator Control Board Replacement, Disconnect the control board: passo 4, imagem 1 %32 LG Refrigerator Control Board Replacement, Disconnect the control board: passo 4, imagem 2 %32 LG Refrigerator Control Board Replacement, Disconnect the control board: passo 4, imagem 3 %32
    • Note the position of each of the connectors, before disconnecting them. A photo is very valuable for keeping track, and taking several as you progress may be helpful.
    • Squeeze and pull the connectors to disconnect them from the control board.
    • Make sure to fully reconnect each connector when reassembling.
    Pergunte ao FixBot
    Comentar
  5. LG Refrigerator Control Board Replacement, Release the control board: passo 5, imagem 1 %32 LG Refrigerator Control Board Replacement, Release the control board: passo 5, imagem 2 %32 LG Refrigerator Control Board Replacement, Release the control board: passo 5, imagem 3 %32
    • Use your thumb to pry up and release the top left retaining clip securing the control board.
    • With your other hand, pull the top left corner of the control board out to loosen it.
    Pergunte ao FixBot
    Comentar
  6. LG Refrigerator Control Board Replacement: passo 6, imagem 1 %32 LG Refrigerator Control Board Replacement: passo 6, imagem 2 %32 LG Refrigerator Control Board Replacement: passo 6, imagem 3 %32
    • Repeat this process for each tab down the left edge of the control board as well as the top and bottom edges.
    Pergunte ao FixBot
    Comentar
  7. LG Refrigerator Control Board Replacement, Remove the control board: passo 7, imagem 1 %32
    • Lift the control board out by its edges and remove it.
    Pergunte ao FixBot
    Comentar
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
4 outras pessoas executaram este guia.
Bill Gilbert
Membro desde: 06/30/22
40.140 Reputação
Autoria de 261 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 31.437 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 46
Últimos 30 dias: 236
Ao todo: 4,855
