Ir para o conteúdo principal
LG Refrigerator Compressor Run Capacitor Replacement
O que você precisa
  1. LG Refrigerator Compressor Run Capacitor Replacement, Unplug your refrigerator: passo 1, imagem 1 %32
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
    Pergunte ao FixBot
    Comentar
  2. LG Refrigerator Compressor Run Capacitor Replacement, Unfasten the control board cover: passo 2, imagem 1 %32
    • Use a Phillips screwdriver to remove the screws securing the control board cover.
    Pergunte ao FixBot
    Comentar
  3. LG Refrigerator Compressor Run Capacitor Replacement, Remove the control board cover: passo 3, imagem 1 %32 LG Refrigerator Compressor Run Capacitor Replacement, Remove the control board cover: passo 3, imagem 2 %32 LG Refrigerator Compressor Run Capacitor Replacement, Remove the control board cover: passo 3, imagem 3 %32
    • Tilt the top edge of the cover toward you and lift it off.
    Pergunte ao FixBot
    Comentar
  4. LG Refrigerator Compressor Run Capacitor Replacement, Unclip the capacitor: passo 4, imagem 1 %32 LG Refrigerator Compressor Run Capacitor Replacement, Unclip the capacitor: passo 4, imagem 2 %32 LG Refrigerator Compressor Run Capacitor Replacement, Unclip the capacitor: passo 4, imagem 3 %32
    • Pull the left edge of the capacitor toward you to unclip it.
    • Handle the capacitor carefully as it may still be charged, and can give a dangerous and painful electrical shock. Avoid touching the terminals with your fingers or hands.
    • For information on capacitor safety, click here.
    Pergunte ao FixBot
    Comentar
  5. LG Refrigerator Compressor Run Capacitor Replacement, Disconnect the capacitor: passo 5, imagem 1 %32 LG Refrigerator Compressor Run Capacitor Replacement, Disconnect the capacitor: passo 5, imagem 2 %32 LG Refrigerator Compressor Run Capacitor Replacement, Disconnect the capacitor: passo 5, imagem 3 %32
    • Pull the connector straight off the capacitor to disconnect it.
    • Remove the capacitor.
    Pergunte ao FixBot
    Comentar
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Uma outra pessoa concluiu este guia.
Bill Gilbert
Membro desde: 06/30/22
40.140 Reputação
Autoria de 261 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 31.437 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 24
Últimos 30 dias: 143
Ao todo: 3,311
