Ir para o conteúdo principal
LG Grace Rear Camera Replacement
O que você precisa
  1. LG Grace Rear Camera Replacement, Phone Assembly: passo 1, imagem 1 %32
    • Find the indentation along the edge of the phone's back and pry open with your nail. A pry tool may help if you have short nails but shouldn't be necessary.
    Pergunte ao FixBot
    Comentar
  2. LG Grace Rear Camera Replacement: passo 2, imagem 1 %32
    • Pull the battery out of the back of the phone. A small indent is present to allow you to pry it out but you may also just flip the phone over and strike it gently against your palm.
    Pergunte ao FixBot
    Comentar
  3. LG Grace Rear Camera Replacement: passo 3, imagem 1 %32 LG Grace Rear Camera Replacement: passo 3, imagem 2 %32
    • Unscrew all of the screws now visible on the back panel of the phone--11 in total. A #00 Phillips screwdriver works here.
    • The screws are M1.3 and 3 mm long.
    Pergunte ao FixBot
    Comentar
  4. LG Grace Rear Camera Replacement: passo 4, imagem 1 %32 LG Grace Rear Camera Replacement: passo 4, imagem 2 %32
    • Insert the Jimmy into the small gap between the edge of the phone screen and body. Gently pry until it pops loose then remove jimmy and use your hands to slowly pry the body away from the screen
    Pergunte ao FixBot
    Comentar
  5. LG Grace Rear Camera Replacement, Rear Camera: passo 5, imagem 1 %32
    • Locate the pin connection for the camera, noted by red box in the guide photo.
    • Gently lift the camera up while pulling away from connection; it should detach with minimal effort.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 28
Ao todo: 322
