Ir para o conteúdo principal
LG G Watch Display Assembly Replacement
O que você precisa
    1. LG G Watch Display Assembly Replacement, Wristband: passo 1, imagem 1 %32
      Ferramenta utilizada neste passo:
      • Spring bars attach the two halves of the wristband to the watch body. The spring bar has a shoulder on either end.
      • Be prepared to apply some pressure with your fingers to perform the following action.
      • First, slide the wristband down on the spring bar to expose the shoulder of the spring bar.
      • Grasp the exposed shoulder with the tweezers to perform the next step.
      Pergunte ao FixBot
      Comentar
    2. LG G Watch Display Assembly Replacement: passo 2, imagem 1 %32 LG G Watch Display Assembly Replacement: passo 2, imagem 2 %32
      • This is a challenging step. Do it carefully to prevent the spring bar from flying out of the wristband.
      • Use the tweezer to depress the spring bar so that it collapses by a few millimeters and pops out of the hole that was holding it in place.
      • Now carefully pull the other end of the spring bar to detach the wristband from the watch face.
      • Repeat steps 1 and 2 for the other wristband.
      Pergunte ao FixBot
      Comentar
    1. LG G Watch Display Assembly Replacement, Rear Case: passo 3, imagem 1 %32
      • Use the T5 Torx screwdriver to unscrew the four silver 2mm x 3mm T5 screws that hold the back cover in place.
      Pergunte ao FixBot
      Comentar
    2. LG G Watch Display Assembly Replacement: passo 4, imagem 1 %32 LG G Watch Display Assembly Replacement: passo 4, imagem 2 %32
      • Slide the opening pick between the rear case and the rest of the device to separate the two halves.
      • Gently pull the two halves apart.
      Pergunte ao FixBot
      Comentar
    1. LG G Watch Display Assembly Replacement, Gasket: passo 5, imagem 1 %32
      • Use a pair of tweezers to remove the gasket that lies embedded in a groove that runs around the perimeter of the front half.
      Pergunte ao FixBot
      Comentar
    1. LG G Watch Display Assembly Replacement, Motherboard: passo 6, imagem 1 %32 LG G Watch Display Assembly Replacement, Motherboard: passo 6, imagem 2 %32
      • Use the spudger to gently lift up and disconnect the display connector.
      • Now use the spudger to disconnect the digitizer connector.
      Pergunte ao FixBot
      Comentar
    2. LG G Watch Display Assembly Replacement: passo 7, imagem 1 %32 LG G Watch Display Assembly Replacement: passo 7, imagem 2 %32
      • Use a Phillips #000 screwdriver to remove the two black PHO 2.5mm x 3mm screws.
      • Use the spudger to gently remove the motherboard.
      Pergunte ao FixBot
      Comentar
    1. LG G Watch Display Assembly Replacement, Removing the screen: passo 8, imagem 1 %32
      • Apply a small amount of pressure to the back of the LCD to create a gap for the opening pick.
      • Gently work the pick around the perimeter of the device to loosen up the adhesive.
      • An iOpener may be necessary to help loosen up the adhesive. Refer to our iOpener guide for info on how to use it.
      Pergunte ao FixBot
      Comentar
    2. LG G Watch Display Assembly Replacement: passo 9, imagem 1 %32 LG G Watch Display Assembly Replacement: passo 9, imagem 2 %32
      • After using the pick to loosen the adhesive, simply pull the display assembly up from the metal bezel.
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
Mandy McGarry
Membro desde: 09/23/14
165 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 2-5, Blackwell Fall 2014 Membro de USF Tampa, Team 2-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G5
5 Membros
Autoria de 9 guias
4Comentários do guia
Where can you purchase replacement parts?
Brian Winebarger - Responder Compartilhar
Someone knows where to find a screen replacement?, i found at alibaba but i have to buy 1k ... :(
George Momo Seyssel - Responder Compartilhar
I found a 00 screwdriver was better than 000 for removing the motherboard.
Peter Jeremy - Responder Compartilhar
Be smart buy a used one for nuthin on eBay….
jeromedaues - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 46
Ao todo: 5,016
