Ir para o conteúdo principal
LG Front Load Washing Machine Main Board Replacement
O que você precisa
  1. LG Front Load Washing Machine Main Board Replacement, Safety Precautions: passo 1, imagem 1 %32 LG Front Load Washing Machine Main Board Replacement, Safety Precautions: passo 1, imagem 2 %32
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
    Pergunte ao FixBot
    Comentar
  2. LG Front Load Washing Machine Main Board Replacement, Unfasten the top panel: passo 2, imagem 1 %32 LG Front Load Washing Machine Main Board Replacement, Unfasten the top panel: passo 2, imagem 2 %32 LG Front Load Washing Machine Main Board Replacement, Unfasten the top panel: passo 2, imagem 3 %32
    • Remove the screw(s) securing the top panel brackets to the back panel.
    • You don't need to remove the screws securing the brackets to the top panel.
    Pergunte ao FixBot
    Comentar
  3. LG Front Load Washing Machine Main Board Replacement, Remove the top panel: passo 3, imagem 1 %32 LG Front Load Washing Machine Main Board Replacement, Remove the top panel: passo 3, imagem 2 %32
    • Slide the top panel towards the rear of the device to disconnect its clips.
    Pergunte ao FixBot
    Comentar
  4. LG Front Load Washing Machine Main Board Replacement: passo 4, imagem 1 %32 LG Front Load Washing Machine Main Board Replacement: passo 4, imagem 2 %32
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
    Pergunte ao FixBot
    Comentar
  5. LG Front Load Washing Machine Main Board Replacement, Disconnect the pressure sensor: passo 5, imagem 1 %32 LG Front Load Washing Machine Main Board Replacement, Disconnect the pressure sensor: passo 5, imagem 2 %32
    • Depending on your device, your pressure sensor might have a wire harness. If so, disconnect each wire on the harness.
    • Disconnect the connector from the pressure sensor.
    • Always grip cables by their connectors and not the wires themselves.
    Pergunte ao FixBot
    Comentar
  6. LG Front Load Washing Machine Main Board Replacement: passo 6, imagem 1 %32 LG Front Load Washing Machine Main Board Replacement: passo 6, imagem 2 %32
    • Disconnect the hose from the pressure sensor.
    Pergunte ao FixBot
    Comentar
  7. LG Front Load Washing Machine Main Board Replacement, Unfasten the pressure sensor: passo 7, imagem 1 %32
    • Remove the screw(s) securing the pressure sensor.
    Pergunte ao FixBot
    Comentar
  8. LG Front Load Washing Machine Main Board Replacement, Remove the pressure sensor: passo 8, imagem 1 %32 LG Front Load Washing Machine Main Board Replacement, Remove the pressure sensor: passo 8, imagem 2 %32 LG Front Load Washing Machine Main Board Replacement, Remove the pressure sensor: passo 8, imagem 3 %32
    • Unclip the pressure sensor from the chassis or other components.
    Pergunte ao FixBot
    Comentar
  9. LG Front Load Washing Machine Main Board Replacement: passo 9, imagem 1 %32 LG Front Load Washing Machine Main Board Replacement: passo 9, imagem 2 %32
    • Lift the pressure sensor away chassis and remove it.
    Pergunte ao FixBot
    Comentar
  10. LG Front Load Washing Machine Main Board Replacement, Disconnect the control panel cover: passo 10, imagem 1 %32 LG Front Load Washing Machine Main Board Replacement, Disconnect the control panel cover: passo 10, imagem 2 %32 LG Front Load Washing Machine Main Board Replacement, Disconnect the control panel cover: passo 10, imagem 3 %32
    • Disconnect any cables or fasteners secured to the control panel cover.
    • Repeat this procedure for any bundled cables that keep the cover from opening.
    Pergunte ao FixBot
    Comentar
  11. LG Front Load Washing Machine Main Board Replacement, Remove the main board cover: passo 11, imagem 1 %32 LG Front Load Washing Machine Main Board Replacement, Remove the main board cover: passo 11, imagem 2 %32 LG Front Load Washing Machine Main Board Replacement, Remove the main board cover: passo 11, imagem 3 %32
    • Use a flathead screwdriver or a prying tool, to unclip the main board cover.
    • Remove the main board cover.
    Pergunte ao FixBot
    Comentar
  12. LG Front Load Washing Machine Main Board Replacement, Unfasten the main board: passo 12, imagem 1 %32 LG Front Load Washing Machine Main Board Replacement, Unfasten the main board: passo 12, imagem 2 %32
    • Remove the screw(s) securing the main board to the back side of the washer.
    Pergunte ao FixBot
    Comentar
  13. LG Front Load Washing Machine Main Board Replacement, Separate the main board from the chassis: passo 13, imagem 1 %32 LG Front Load Washing Machine Main Board Replacement, Separate the main board from the chassis: passo 13, imagem 2 %32 LG Front Load Washing Machine Main Board Replacement, Separate the main board from the chassis: passo 13, imagem 3 %32
    • Slide the main board out of its slot in the chassis.
    Pergunte ao FixBot
    Comentar
  14. LG Front Load Washing Machine Main Board Replacement, Remove the main board: passo 14, imagem 1 %32 LG Front Load Washing Machine Main Board Replacement, Remove the main board: passo 14, imagem 2 %32 LG Front Load Washing Machine Main Board Replacement, Remove the main board: passo 14, imagem 3 %32
    • Label each connector and its spot on the main board. During reassembly, reattach each connector to its proper spot.
    • Lift the main board out of the chassis to access each of the connectors.
    • Disconnect each connector from the main board.
    • Remove the main board.
    Pergunte ao FixBot
    Comentar
Conclusão
Repair didn’t go as planned? Ask our Answers community for help.
Uma outra pessoa concluiu este guia.
Bill Gilbert
Membro desde: 06/30/22
40.137 Reputação
Autoria de 261 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 28.230 guias
1Comentário do guia
Thank you for the instructions. Can power to the front control panel be tested without connecting the pressure sensor and water lines.
albert - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 20
Últimos 30 dias: 109
Ao todo: 4,221
