Ir para o conteúdo principal
LG Front Load Washing Machine Control Panel Replacement
O que você precisa
  1. LG Front Load Washing Machine Control Panel Replacement, Safety Precautions: passo 1, imagem 1 %32 LG Front Load Washing Machine Control Panel Replacement, Safety Precautions: passo 1, imagem 2 %32
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
    Pergunte ao FixBot
    Comentar
  2. LG Front Load Washing Machine Control Panel Replacement, Unfasten the top panel: passo 2, imagem 1 %32 LG Front Load Washing Machine Control Panel Replacement, Unfasten the top panel: passo 2, imagem 2 %32 LG Front Load Washing Machine Control Panel Replacement, Unfasten the top panel: passo 2, imagem 3 %32
    • Remove the screw(s) securing the top panel brackets to the back panel.
    • You don't need to remove the screws securing the brackets to the top panel.
    Pergunte ao FixBot
    Comentar
  3. LG Front Load Washing Machine Control Panel Replacement, Remove the top panel: passo 3, imagem 1 %32 LG Front Load Washing Machine Control Panel Replacement, Remove the top panel: passo 3, imagem 2 %32
    • Slide the top panel towards the rear of the device to disconnect its clips.
    Pergunte ao FixBot
    Comentar
  4. LG Front Load Washing Machine Control Panel Replacement: passo 4, imagem 1 %32 LG Front Load Washing Machine Control Panel Replacement: passo 4, imagem 2 %32
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
    Pergunte ao FixBot
    Comentar
  5. LG Front Load Washing Machine Control Panel Replacement, Remove the detergent drawer: passo 5, imagem 1 %32 LG Front Load Washing Machine Control Panel Replacement, Remove the detergent drawer: passo 5, imagem 2 %32
    • Pull the detergent drawer away from the chassis as far as it will go.
    Pergunte ao FixBot
    Comentar
  6. LG Front Load Washing Machine Control Panel Replacement: passo 6, imagem 1 %32 LG Front Load Washing Machine Control Panel Replacement: passo 6, imagem 2 %32 LG Front Load Washing Machine Control Panel Replacement: passo 6, imagem 3 %32
    • Press down on the "Push" button to disengage the clips securing the detergent drawer.
    • Pull the drawer out of its slot on the chassis and remove it.
    Pergunte ao FixBot
    Comentar
  7. LG Front Load Washing Machine Control Panel Replacement, Disconnect the control panel: passo 7, imagem 1 %32 LG Front Load Washing Machine Control Panel Replacement, Disconnect the control panel: passo 7, imagem 2 %32 LG Front Load Washing Machine Control Panel Replacement, Disconnect the control panel: passo 7, imagem 3 %32
    • Disconnect the connectors attached to the control panel.
    • Always grip cables by their connectors and not the wires themselves.
    Pergunte ao FixBot
    Comentar
  8. LG Front Load Washing Machine Control Panel Replacement, Unfasten the control panel: passo 8, imagem 1 %32 LG Front Load Washing Machine Control Panel Replacement, Unfasten the control panel: passo 8, imagem 2 %32
    • Remove the screw(s) securing the control panel.
    Pergunte ao FixBot
    Comentar
  9. LG Front Load Washing Machine Control Panel Replacement, Unfasten the detergent dispenser: passo 9, imagem 1 %32
    • Remove the screw(s) securing the detergent dispenser.
    Pergunte ao FixBot
    Comentar
  10. LG Front Load Washing Machine Control Panel Replacement, Unclip the control panel: passo 10, imagem 1 %32 LG Front Load Washing Machine Control Panel Replacement, Unclip the control panel: passo 10, imagem 2 %32 LG Front Load Washing Machine Control Panel Replacement, Unclip the control panel: passo 10, imagem 3 %32
    • Use a flathead screwdriver, or a pry tool, to unclip the control panel from the chassis.
    Pergunte ao FixBot
    Comentar
  11. LG Front Load Washing Machine Control Panel Replacement, Remove the control panel: passo 11, imagem 1 %32 LG Front Load Washing Machine Control Panel Replacement, Remove the control panel: passo 11, imagem 2 %32 LG Front Load Washing Machine Control Panel Replacement, Remove the control panel: passo 11, imagem 3 %32
    • Remove the control panel, making sure to thread any cables through the chassis.
    Pergunte ao FixBot
    Comentar
  12. LG Front Load Washing Machine Control Panel Replacement, Unfasten the control panel board: passo 12, imagem 1 %32
    • Flip the control panel over.
    • Remove the screw(s) securing the control panel board.
    Pergunte ao FixBot
    Comentar
  13. LG Front Load Washing Machine Control Panel Replacement, Remove the control panel board: passo 13, imagem 1 %32 LG Front Load Washing Machine Control Panel Replacement, Remove the control panel board: passo 13, imagem 2 %32 LG Front Load Washing Machine Control Panel Replacement, Remove the control panel board: passo 13, imagem 3 %32
    • Pull the control panel board out of its slot and remove it.
    Pergunte ao FixBot
    Comentar
Conclusão
Repair didn’t go as planned? Ask our Answers community for help.
3 outras pessoas executaram este guia.
Bill Gilbert
Membro desde: 06/30/22
40.137 Reputação
Autoria de 261 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 28.230 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 9
Últimos 7 dias: 49
Últimos 30 dias: 234
Ao todo: 5,452
