Introdução
Is your tablet not turning on or has a shorter battery life? Then it is time to replace the battery and this guide will help you in doing so. This guide does require soldering so please refer to this guide.
O que você precisa
Use the Phillips #0 Screwdriver to remove four 5mm screws from sides of the device.
