Ir para o conteúdo principal
Kodak EasyShare CD82 Lens Assembly Replacement
O que você precisa
  1. Kodak EasyShare CD82 Lens Assembly Replacement, Lens Assembly: passo 1, imagem 1 %32 Kodak EasyShare CD82 Lens Assembly Replacement, Lens Assembly: passo 1, imagem 2 %32 Kodak EasyShare CD82 Lens Assembly Replacement, Lens Assembly: passo 1, imagem 3 %32
    • Remove the batteries and the memory card from the device.
    • Remove the two screws located at the bottom of the camera.
    Pergunte ao FixBot
    Comentar
  2. Kodak EasyShare CD82 Lens Assembly Replacement: passo 2, imagem 1 %32 Kodak EasyShare CD82 Lens Assembly Replacement: passo 2, imagem 2 %32 Kodak EasyShare CD82 Lens Assembly Replacement: passo 2, imagem 3 %32
    • Remove the two screws on the side of the device, to left of the camera lens.
    • Remove the two screws on side of the device, to the right of the camera lens.
    • Pry the casing apart at the seems, starting at the battery compartment.
    Pergunte ao FixBot
    Comentar
  3. Kodak EasyShare CD82 Lens Assembly Replacement: passo 3, imagem 1 %32 Kodak EasyShare CD82 Lens Assembly Replacement: passo 3, imagem 2 %32 Kodak EasyShare CD82 Lens Assembly Replacement: passo 3, imagem 3 %32
    • Remove the front casing from the mid-frame, first.
    • Continue to remove the back casing from the mid-frame.
    • Do not remove the LCD screen from the device once it becomes visible.
    Pergunte ao FixBot
    Comentar
  4. Kodak EasyShare CD82 Lens Assembly Replacement: passo 4, imagem 1 %32 Kodak EasyShare CD82 Lens Assembly Replacement: passo 4, imagem 2 %32 Kodak EasyShare CD82 Lens Assembly Replacement: passo 4, imagem 3 %32
    • Flip the LCD screen out of the holder from the top to reveal ribbon cable.
    • This camera had some obvious water damage..
    • Remove the three screws from the LCD holder
    • Dislodge the LCD screen holder from the circuit board connector.
    Pergunte ao FixBot
    Comentar
  5. Kodak EasyShare CD82 Lens Assembly Replacement: passo 5, imagem 1 %32 Kodak EasyShare CD82 Lens Assembly Replacement: passo 5, imagem 2 %32 Kodak EasyShare CD82 Lens Assembly Replacement: passo 5, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Disconnect the logic board from the frame on the right side of the device.
    • Remove the small ribbon cable, connecting the button board to the logic board, with small pair of tweezers or hemostat.
    • Remove the screw on the top right side of the device connecting the LCD screen holder to the midframe.
    • Move the black clip into the upward position to disconnect the cable.
    • You will now be able to remove the LCD screen and its holder from the device.
    Pergunte ao FixBot
    Comentar
  6. Kodak EasyShare CD82 Lens Assembly Replacement: passo 6, imagem 1 %32 Kodak EasyShare CD82 Lens Assembly Replacement: passo 6, imagem 2 %32 Kodak EasyShare CD82 Lens Assembly Replacement: passo 6, imagem 3 %32
    • Flip the black clips of the connectors into the opposite direction. Remove the lens and CCD cable.
    • Remove the two screws securing the lens to the midframe.
    • These are missing screws for the CCD sensor, lost in a previous dismantling.
    • Remove the single screw securing the lens to the mid-frame. The lens will now be loose.
    • Push the lens out of the frame in an angular direction, and remove.
    Pergunte ao FixBot
    Comentar
  7. Kodak EasyShare CD82 Lens Assembly Replacement: passo 7, imagem 1 %32
    • Insert the new lens the same way it was removed.
    • Clean and reassemble the camera.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
oldturkey03
Membro desde: 09/29/10
855.793 Reputação
Autoria de 123 guias
1Comentário do guia
When it says "Dislodge the LCD screen holder from the circuit board connector" does it mean that I can break that solder without desoldering and it's okay?
Sith Siri - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 17
Últimos 30 dias: 52
Ao todo: 2,261
