Ir para o conteúdo principal
Kindle Fire Back Case Replacement
O que você precisa
  1. Kindle Fire Back Case Replacement, Back Case: passo 1, imagem 1 %32 Kindle Fire Back Case Replacement, Back Case: passo 1, imagem 2 %32 Kindle Fire Back Case Replacement, Back Case: passo 1, imagem 3 %32
    • Wedge a plastic opening tool into the lower right corner of the Kindle Fire.
    • Pry the case apart and run the plastic opening tool along the perimeter of the Kindle Fire to release the clips securing the case halves to each other.
    • If you are having extreme difficulty inserting the plastic opening tool, carefully use a metal spudger to undo the first clip, then switch back to the opening tool to avoid scratching your case.
    • It is helpful to pry the bottom of the Kindle Fire away (and out from the side) from the top part. Exerting too much force attempting to split the two without pulling away can cause the tabs on the inside to crack.
    Pergunte ao FixBot
    Comentar
  2. Kindle Fire Back Case Replacement: passo 2, imagem 1 %32
    • Once you have freed all the plastic clips, pull the back case off the Kindle Fire.
    Pergunte ao FixBot
    Comentar
Conclusão
14 outras pessoas executaram este guia.
Phillip Takahashi
Membro desde: 08/22/11
87.893 Reputação
Autoria de 87 guias
3Comentários do guia
Simple to follow instructions .
Eric Rester - Responder Compartilhar
where to buy the base panel for my kindle fire 7 tablet
Senthilvel Murugesan - Responder Compartilhar
I was wondering why my kindle case was opening/separating and it was not charging. I opened the case per you instructions and found that the battery has expanded inside ITS case! I hope to be able to get another battery cheaply. Thank you for your help!!
Ellen De - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 19
Últimos 30 dias: 78
Ao todo: 17,491
