Ir para o conteúdo principal
JBL Xtreme 2 Battery Replacement
O que você precisa
  1. JBL Xtreme 2 Battery Replacement, Pry up the fabric cover: passo 1, imagem 1 %32 JBL Xtreme 2 Battery Replacement, Pry up the fabric cover: passo 1, imagem 2 %32 JBL Xtreme 2 Battery Replacement, Pry up the fabric cover: passo 1, imagem 3 %32
    • Before starting repairs, turn off your device and unplug any cables.
    • The fabric cover of the JBL Xtreme 2 is secured by plastic clips and screws. To avoid damaging the cover, begin prying on the edge closest to the ports.
    • Insert the flat end of a metal spudger into the seam between the two halves of the fabric cover.
    • Push the spudger underneath the edge of the fabric cover and pry upwards to release its plastic clips.
  2. JBL Xtreme 2 Battery Replacement, Release the plastic clips: passo 2, imagem 1 %32 JBL Xtreme 2 Battery Replacement, Release the plastic clips: passo 2, imagem 2 %32 JBL Xtreme 2 Battery Replacement, Release the plastic clips: passo 2, imagem 3 %32
    • Insert the flat end of a metal spudger underneath the edge of the fabric cover's center section.
  3. JBL Xtreme 2 Battery Replacement, Pry up the second short edge: passo 3, imagem 1 %32 JBL Xtreme 2 Battery Replacement, Pry up the second short edge: passo 3, imagem 2 %32
    • Insert the flat end of a metal spudger underneath the second short edge of the fabric cover.
  4. JBL Xtreme 2 Battery Replacement, Unfasten the fabric cover: passo 4, imagem 1 %32 JBL Xtreme 2 Battery Replacement, Unfasten the fabric cover: passo 4, imagem 2 %32
    • Use a Phillips screwdriver to remove the two 8.6 mm-long screws securing the fabric cover.
    • Don't try to remove the fabric cover all the way yet, as it‘s still held in place by more plastic clips.
  5. JBL Xtreme 2 Battery Replacement, Pry up the short edge of the fabric cover: passo 5, imagem 1 %32 JBL Xtreme 2 Battery Replacement, Pry up the short edge of the fabric cover: passo 5, imagem 2 %32
    • Repeat the previous prying procedure, starting with the opposing short edge of the fabric cover.
    • Insert the flat end of a metal spudger and pry upwards to release the plastic clips.
  6. JBL Xtreme 2 Battery Replacement, Pry up the long edge of the fabric cover: passo 6, imagem 1 %32 JBL Xtreme 2 Battery Replacement, Pry up the long edge of the fabric cover: passo 6, imagem 2 %32 JBL Xtreme 2 Battery Replacement, Pry up the long edge of the fabric cover: passo 6, imagem 3 %32
    • Insert the flat end of a metal spudger underneath the long edge of the fabric cover and pry upwards to release the plastic clips.
  7. JBL Xtreme 2 Battery Replacement, Release the remaining plastic clip: passo 7, imagem 1 %32 JBL Xtreme 2 Battery Replacement, Release the remaining plastic clip: passo 7, imagem 2 %32
    • Insert the flat end of a metal spudger underneath the short edge of the fabric cover and pry upwards to release the remaining plastic clip.
  8. JBL Xtreme 2 Battery Replacement, Open the fabric cover: passo 8, imagem 1 %32 JBL Xtreme 2 Battery Replacement, Open the fabric cover: passo 8, imagem 2 %32
    • The fabric cover of the JBL Xtreme 2 is equipped with a hinge.
    • Place your speaker on your working surface with the Xtreme 2 branding facing upwards.
    • Open the hinge of the fabric cover by folding it upwards.
  9. JBL Xtreme 2 Battery Replacement, Remove the fabric cover: passo 9, imagem 1 %32 JBL Xtreme 2 Battery Replacement, Remove the fabric cover: passo 9, imagem 2 %32 JBL Xtreme 2 Battery Replacement, Remove the fabric cover: passo 9, imagem 3 %32
    • Lift the speaker assembly up and away from the fabric cover.
    • Remove the fabric cover.
  10. JBL Xtreme 2 Battery Replacement, Unfasten the battery cover: passo 10, imagem 1 %32 JBL Xtreme 2 Battery Replacement, Unfasten the battery cover: passo 10, imagem 2 %32
    • Use a Phillips screwdriver to remove the six 8.6 mm-long screws securing the battery cover.
  11. JBL Xtreme 2 Battery Replacement, Remove the battery cover: passo 11, imagem 1 %32 JBL Xtreme 2 Battery Replacement, Remove the battery cover: passo 11, imagem 2 %32
    • Remove the battery cover.
  12. JBL Xtreme 2 Battery Replacement, Pry up the battery: passo 12, imagem 1 %32 JBL Xtreme 2 Battery Replacement, Pry up the battery: passo 12, imagem 2 %32
    • Insert a spuder into the gap between the bottom end of the battery and its recess.
    • Pry upwards to lift the battery until you can grip it with your fingers.
  13. JBL Xtreme 2 Battery Replacement, Move the battery: passo 13, imagem 1 %32 JBL Xtreme 2 Battery Replacement, Move the battery: passo 13, imagem 2 %32
    • Avoid straining or sharply bending the battery cable during the following step. Move the battery just enough to get access to the battery connector.
    • Lift the battery out of its recess and carefully pull it to the side to get free access to the battery connector.
    • During reassembly, this is a good point to power on your device and test your repair before reinstalling the fabric cover.
  14. JBL Xtreme 2 Battery Replacement, Disconnect the battery: passo 14, imagem 1 %32 JBL Xtreme 2 Battery Replacement, Disconnect the battery: passo 14, imagem 2 %32 JBL Xtreme 2 Battery Replacement, Disconnect the battery: passo 14, imagem 3 %32
    • The battery is connected to the motherboard with a power cable connector that has a small tab on the side that locks it in place.
    • Insert a spudger into the cut-out in the battery recess where the battery connector is located.
    • Use your spudger to squeeze the tab against the connector to release it.
    • Use your free hand to grab the battery cable just above the connector. Pull the connector straight up from its socket, wiggling it back and forth to loosen the clips securing it.
  15. JBL Xtreme 2 Battery Replacement, Remove the battery: passo 15, imagem 1 %32
    • Remove the battery.
Conclusão
If possible, power on your device and test your repair before reassembly. For optimal performance, calibrate your newly installed battery after completing this guide.
4 outras pessoas executaram este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
204.379 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 136
Autoria de 17.299 guias
Um comentário
My JBL stop working, it's connected wi/fi on, but no sound
Adam Cleveland - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 9
Últimos 7 dias: 55
Últimos 30 dias: 264
Duração total: 2,842
