Ir para o conteúdo principal
JBL Tune 510BT Power Button Replacement
O que você precisa
  1. JBL Tune 510BT Power Button Replacement, Faceplate: passo 1, imagem 1 %32 JBL Tune 510BT Power Button Replacement, Faceplate: passo 1, imagem 2 %32
    • Firmly grasp the earmuff and pull away from the center until the lip of the earmuff is disengaged.
    • Pull the earmuff towards the center of the headphones until it is free.
    Pergunte ao FixBot
    Comentar
  2. JBL Tune 510BT Power Button Replacement: passo 2, imagem 1 %32 JBL Tune 510BT Power Button Replacement: passo 2, imagem 2 %32
    • Remove the three 3 mm screws using a JIS #00 screwdriver.
    Pergunte ao FixBot
    Comentar
  3. JBL Tune 510BT Power Button Replacement: passo 3, imagem 1 %32
    • Carefully remove the faceplate by lifting it firmly.
    • Avoid rough movements, as there is a single thin wire connecting the faceplate to the internals.
    • If the repair is for the right-side driver, be mindful of the charging port, as the faceplate has a slot there for it. Lift the opposite end and back the port out.
    • To completely detach the faceplate, desolder the wires from the connections on the motherboard.
    Pergunte ao FixBot
    Comentar
  4. JBL Tune 510BT Power Button Replacement, Power Button: passo 4, imagem 1 %32 JBL Tune 510BT Power Button Replacement, Power Button: passo 4, imagem 2 %32
    • Remove the 1 mm screw using a JIS #00 screwdriver.
    • Using your finger or a Jimmy, gently pry the circuit board from the casing, being careful to not pull too hard to dislodge the connected wires.
    Pergunte ao FixBot
    Comentar
  5. JBL Tune 510BT Power Button Replacement: passo 5, imagem 1 %32 JBL Tune 510BT Power Button Replacement: passo 5, imagem 2 %32
    • Gently push the damaged power button from the outside towards the inner part of the headphone casing until it dislodges.
    • Replace it with the new button by connecting the tabs at the top and swinging the button into place.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Andy Rich
Membro desde: 01/30/24
316 Reputação
Autoria de 2 guias
Equipe
2Comentários do guia
Ref. Power button ?
Marcel De Taey - Responder Compartilhar
Part number to replace the powder button?? 510BT
Chris - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 79
Últimos 30 dias: 336
Ao todo: 7,182
