Ir para o conteúdo principal
JBL Flip Speaker Replacement
O que você precisa
  1. JBL Flip Speaker Replacement, JBL Flip disassembly: passo 1, imagem 1 %32 JBL Flip Speaker Replacement, JBL Flip disassembly: passo 1, imagem 2 %32 JBL Flip Speaker Replacement, JBL Flip disassembly: passo 1, imagem 3 %32
    • On the end with the buttons, remove the end cap using the flat head screwdriver to get between the rubber lining and the plastic.
    • After the cap is removed, unscrew the two 3.3mm screws using a size 1 ph screw driver.
    Pergunte ao FixBot
    Comentar
  2. JBL Flip Speaker Replacement: passo 2, imagem 1 %32 JBL Flip Speaker Replacement: passo 2, imagem 2 %32 JBL Flip Speaker Replacement: passo 2, imagem 3 %32
    • Unscrew four 3.3mm screws on each end of the JBL using a size 1 ph screw driver (8 screws total).
    Pergunte ao FixBot
    Comentar
  3. JBL Flip Speaker Replacement: passo 3, imagem 1 %32 JBL Flip Speaker Replacement: passo 3, imagem 2 %32 JBL Flip Speaker Replacement: passo 3, imagem 3 %32
    • Remove outermost white casing by gently lifting up on one side.
    • Remove two 5mm screws holding the silver back plate in place with a size 2 ph screw driver.
    • Gently lift up and remove the silver casing.
    Pergunte ao FixBot
    Comentar
  4. JBL Flip Speaker Replacement: passo 4, imagem 1 %32
    • Remove last white back plate to expose the back of the speaker cover.
    Pergunte ao FixBot
    Comentar
  5. JBL Flip Speaker Replacement: passo 5, imagem 1 %32 JBL Flip Speaker Replacement: passo 5, imagem 2 %32 JBL Flip Speaker Replacement: passo 5, imagem 3 %32
    • Pry the four tabs on each side of the speaker cover (8 tabs total).
    • Pry the two tabs on each end to remove the cover (4 tabs total).
    • Slide speaker out of metal speaker cover.
    Pergunte ao FixBot
    Comentar
  6. JBL Flip Speaker Replacement: passo 6, imagem 1 %32 JBL Flip Speaker Replacement: passo 6, imagem 2 %32 JBL Flip Speaker Replacement: passo 6, imagem 3 %32
    • Remove 5mm screw in the middle of the back of the device with a size 2 ph screw driver.
    • Unscrew the two 5mm screws on each side using a size 2 ph screwdriver.
    • Open the speaker.
    Pergunte ao FixBot
    Comentar
  7. JBL Flip Speaker Replacement, Speaker: passo 7, imagem 1 %32 JBL Flip Speaker Replacement, Speaker: passo 7, imagem 2 %32 JBL Flip Speaker Replacement, Speaker: passo 7, imagem 3 %32
    • Remove screws that hold the plastic L-pipe in place.
    Pergunte ao FixBot
    Comentar
  8. JBL Flip Speaker Replacement: passo 8, imagem 1 %32 JBL Flip Speaker Replacement: passo 8, imagem 2 %32
    • Remove L-pipe.
    • Remove two screws on each speaker.
    • Remove speakers.
    Pergunte ao FixBot
    Comentar
  9. JBL Flip Speaker Replacement: passo 9, imagem 1 %32 JBL Flip Speaker Replacement: passo 9, imagem 2 %32 JBL Flip Speaker Replacement: passo 9, imagem 3 %32
    • Take a soldering iron to the two solders, one for each cable.
    • Soldering iron will be very hot.
    • Once the soldering has melted, remove each wire from the speaker.
    Pergunte ao FixBot
    Comentar
Conclusão
8 outras pessoas executaram este guia.
Dillon
Membro desde: 03/11/15
1.601 Reputação
Autoria de 5 guias
Equipe
9Comentários do guia
I want JBL flip 2 charging commector board.
Where can i buy ??
Plz help me
feroz4u786 - Responder Compartilhar
Where do you buy the replacement speakers?
ingridxpan - Responder Compartilhar
I have a problem with the bluetooth of my speaker goes off after 10 minutes of running I have checked with several smart and it always repeats that I can do
Alvaro Rivas Rodriguez - Responder Compartilhar
Where I can get schematic diagram and plans of this equipment
I want to buy 2pcs replacement speaker for my JBL flip bluetooth speaker. Ho can I buy .and from
jonessangeeta - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 66
Ao todo: 43,600
