Ir para o conteúdo principal
Insignia NS-CSPBTHOL-R Buttons Replacement
O que você precisa
  1. Insignia NS-CSPBTHOL-R Buttons Replacement, Buttons: passo 1, imagem 1 %32 Insignia NS-CSPBTHOL-R Buttons Replacement, Buttons: passo 1, imagem 2 %32
    • Use the spudger to pry off the plastic grate covering the speakers, then gently pull it off with your fingers.
    Pergunte ao FixBot
    Comentar
  2. Insignia NS-CSPBTHOL-R Buttons Replacement: passo 2, imagem 1 %32
    • once the grate has been removed, Remove the six 3mm screws using the J00 JIS screw bit. This will require a long, narrow screwdriver.
    Pergunte ao FixBot
    Comentar
  3. Insignia NS-CSPBTHOL-R Buttons Replacement: passo 3, imagem 1 %32
    • Insert the Spudger between the corners of base and the face of the speaker to open the device. The screw on the upper right corner may be difficult to take out. If you cannot take it out with a screwdriver, using force to pull the face of the speaker apart may break the plastic that surrounds the screw.
    Pergunte ao FixBot
    Comentar
  4. Insignia NS-CSPBTHOL-R Buttons Replacement: passo 4, imagem 1 %32 Insignia NS-CSPBTHOL-R Buttons Replacement: passo 4, imagem 2 %32 Insignia NS-CSPBTHOL-R Buttons Replacement: passo 4, imagem 3 %32
    • Gently pull apart the speaker to separate the speakers from the battery and motherboard. Then pull out the motherboard with your fingers by grabbing the edges and pulling upwards.
    Pergunte ao FixBot
    Comentar
  5. Insignia NS-CSPBTHOL-R Buttons Replacement: passo 5, imagem 1 %32 Insignia NS-CSPBTHOL-R Buttons Replacement: passo 5, imagem 2 %32
    • Desolder the four contact points from the button that is unresponsive.
    • Check out this helpful guide for soldering and desoldering tips.
    Pergunte ao FixBot
    Comentar
Conclusão
Zachary Foltz
Membro desde: 02/15/17
101 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 12-6, Eyestone Spring 2017 Membro de USF Tampa, Team 12-6, Eyestone Spring 2017
USFT-EYESTONE-S17S12G6
3 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 27
Ao todo: 641
