Ir para o conteúdo principal
Insignia NS-CLLT01 Button Replacement
O que você precisa
  1. Insignia NS-CLLT01 Button Replacement, Insignia NS-CLLT01 Top Casing Removal: passo 1, imagem 1 %32 Insignia NS-CLLT01 Button Replacement, Insignia NS-CLLT01 Top Casing Removal: passo 1, imagem 2 %32
    • Lift the four adhesive covers on each of the corners on the bottom of the clock using a plastic opening tool or your fingernail.
    Pergunte ao FixBot
    Comentar
  2. Insignia NS-CLLT01 Button Replacement: passo 2, imagem 1 %32 Insignia NS-CLLT01 Button Replacement: passo 2, imagem 2 %32 Insignia NS-CLLT01 Button Replacement: passo 2, imagem 3 %32
    • On the bottom of the clock, use your fingernail to push the battery cover to the right.
    • Lift the battery cover up and to the right to reveal the batteries.
    Pergunte ao FixBot
    Comentar
  3. Insignia NS-CLLT01 Button Replacement: passo 3, imagem 1 %32
    • Remove the two AA batteries by pressing the end opposite of the spring towards that spring and lifting up.
    • Once the batteries are removed, close the cover.
    Pergunte ao FixBot
    Comentar
  4. Insignia NS-CLLT01 Button Replacement: passo 4, imagem 1 %32
    • Use a long Phillips #2 screwdriver to unscrew all six 10mm Phillips screws inside the bottom of the clock.
    • Turn over the device to allow the screws to fall out, being careful to catch them so that you do not lose any.
    • The screws may not come out of the bottom of the clock. As long as you have unscrewed them, the clock can still be opened.
    Pergunte ao FixBot
    Comentar
  5. Insignia NS-CLLT01 Button Replacement: passo 5, imagem 1 %32 Insignia NS-CLLT01 Button Replacement: passo 5, imagem 2 %32 Insignia NS-CLLT01 Button Replacement: passo 5, imagem 3 %32
    • Turn the clock back over.
    • Lift the top off of the clock by gripping the back of the iPhone dock and pulling straight up.
    Pergunte ao FixBot
    Comentar
  6. Insignia NS-CLLT01 Button Replacement, Button: passo 6, imagem 1 %32
    • Using the Phillips #2 screwdriver, unscrew the seven 6mm Phillips screws on the circuit board that is attached to the top of the case.
    Pergunte ao FixBot
    Comentar
  7. Insignia NS-CLLT01 Button Replacement: passo 7, imagem 1 %32
    • Lift the circuit board from the device.
    Pergunte ao FixBot
    Comentar
  8. Insignia NS-CLLT01 Button Replacement: passo 8, imagem 1 %32 Insignia NS-CLLT01 Button Replacement: passo 8, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Detach the circuit board from the rest of the clock by gripping the sides of the white ribbon cable connector on the left-hand side of the board and pulling it straight off. You may need to use tweezers to grip the connector.
    Pergunte ao FixBot
    Comentar
  9. Insignia NS-CLLT01 Button Replacement: passo 9, imagem 1 %32 Insignia NS-CLLT01 Button Replacement: passo 9, imagem 2 %32 Insignia NS-CLLT01 Button Replacement: passo 9, imagem 3 %32
    • Use this soldering guide to remove and replace any buttons that were not working.
    • The buttons will be labeled on the top of the circuit board, and you will be working with the corresponding connections on the back.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
Baylor, Team 6-9, Williams Fall 2015 Membro de Baylor, Team 6-9, Williams Fall 2015
BU-WILLIAMS-F15S6G9
3 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 29
Ao todo: 633
