Ir para o conteúdo principal
Insignia Flex 8 Battery Replacement
O que você precisa
  1. Insignia Flex 8 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the power is off to avoid injury in the following steps.
    • Position the tablet so that the screen is face down.
    • The power button is located in the upper left hand corner.
    • Hold the power button for three seconds until the tablet powers down.
    Pergunte ao FixBot
    Comentar
  2. Insignia Flex 8 Battery Replacement: passo 2, imagem 1 %32 Insignia Flex 8 Battery Replacement: passo 2, imagem 2 %32
    • Remove the back casing by sliding a credit card or a similarly thin but firm object in between the casing and the screen.
    • Run this object around the perimeter of the tablet until there is separation between the casing and the screen.
    • Remove the back casing and set aside.
    Pergunte ao FixBot
    Comentar
  3. Insignia Flex 8 Battery Replacement: passo 3, imagem 1 %32
    • Peel back the tape from battery and case.
    Pergunte ao FixBot
    Comentar
  4. Insignia Flex 8 Battery Replacement: passo 4, imagem 1 %32
    • Slide the spudger beneath battery to pry away it away from the case. Work around the battery, prying up all edges to remove from glue.
    • Do not puncture or bend battery. This could cause battery to leak acid.
    Pergunte ao FixBot
    Comentar
  5. Insignia Flex 8 Battery Replacement: passo 5, imagem 1 %32
    • Desolder the black, yellow and red connections from circuit board. Desoldering Help
    • Keep the soldering tool away from other components on the circuit board.
    Pergunte ao FixBot
    Comentar
Conclusão
4 outras pessoas executaram este guia.
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 27
Ao todo: 9,405
