Ir para o conteúdo principal
InFocus Screenplay 4805 Lamp Replacement
O que você precisa
  1. InFocus Screenplay 4805 Lamp Replacement, Remove the lamp door: passo 1, imagem 1 %32
    • Front panel assembly removal is not required.
    • To remove the lamp door, use a metal or plastic pry tool and unclip the lamp door from the projector. Set this aside for reassembly.
    Pergunte ao FixBot
    Comentar
  2. InFocus Screenplay 4805 Lamp Replacement, Disconnect the lamp: passo 2, imagem 1 %32 InFocus Screenplay 4805 Lamp Replacement, Disconnect the lamp: passo 2, imagem 2 %32 InFocus Screenplay 4805 Lamp Replacement, Disconnect the lamp: passo 2, imagem 3 %32
    • Beyond this step, the lamp can be replaced as an assembly and the guide is complete. If you want to rebuild the lamp with a new bulb and reuse the old housing, refer to this guide: InFocus Screenplay 4805 Lamp Rebuild
    • If you are replacing the lamp as an assembly, follow this guide in reverse from this step.
    • Remove the two gold 1 cm screws and washers on the side of lens housing using the 4.0 flat-head bit
    • Pinch the white wire tab to gently detach the side that connects with the lens housing.
    Pergunte ao FixBot
    Comentar
  3. InFocus Screenplay 4805 Lamp Replacement, **REBUILD ONLY** Housing disassembly: passo 3, imagem 1 %32 InFocus Screenplay 4805 Lamp Replacement, **REBUILD ONLY** Housing disassembly: passo 3, imagem 2 %32
    • This step is only required when rebuilding the old lamp with a replacement bulb.
    • Slide the bulb housing out of the projector.
    • Use the Phillips #1 screwdriver to remove the three 1 cm gold screws on the bulb housing.
    Pergunte ao FixBot
    Comentar
  4. InFocus Screenplay 4805 Lamp Replacement, **REBUILD ONLY** Housing disassembly: passo 4, imagem 1 %32 InFocus Screenplay 4805 Lamp Replacement, **REBUILD ONLY** Housing disassembly: passo 4, imagem 2 %32
    • Gently pull the top of the bulb housing off.
    • Lift up the middle of the bulb housing to remove it.
    • Be careful of loose parts, such as the metal housing and the glass focusing lens.
    Pergunte ao FixBot
    Comentar
  5. InFocus Screenplay 4805 Lamp Replacement, **REBUILD ONLY** Housing disassembly: passo 5, imagem 1 %32 InFocus Screenplay 4805 Lamp Replacement, **REBUILD ONLY** Housing disassembly: passo 5, imagem 2 %32 InFocus Screenplay 4805 Lamp Replacement, **REBUILD ONLY** Housing disassembly: passo 5, imagem 3 %32
    • Unhook the spring from the bulb housing.
    • Gently remove the bulb.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble the device, follow these instructions in reverse order.
Uma outra pessoa concluiu este guia.
3Comentários do guia
To remove and later disassemble the lamp, you don’t need to remove whole cover. Just open the lamp bay door and follow the steps starting  from 6!
madyogi - Responder Compartilhar
madyogi, exactly. You are absolutely right!
ilya.zhizhin - Responder Compartilhar
I was able to fix an old projector I got for $40. Thank you so much for the tutorial.
Madelyn Tapia - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 24
Ao todo: 1,939
