Ir para o conteúdo principal
InFocus Screenplay 4805 Lamp Rebuild
O que você precisa
  1. InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: passo 1, imagem 1 %32 InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: passo 1, imagem 2 %32
    • This guide assumes tht you have removed the lamp unit from the projector. If you have not, refer to this guide first: InFocus Screenplay 4805 Lamp Replacement
    • Slide the bulb housing out of the projector.
    • Use the Phillips #1 screwdriver to remove the three 1 cm gold screws on the bulb housing.
    Pergunte ao FixBot
    Comentar
  2. InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: passo 2, imagem 1 %32 InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: passo 2, imagem 2 %32
    • This step is only required when rebuilding the old lamp with a replacement bulb.
    • Gently pull the top of the bulb housing off.
    • Lift up the middle of the bulb housing to remove it.
    • Be careful of loose parts, such as the metal housing and the glass focusing lens.
    Pergunte ao FixBot
    Comentar
  3. InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: passo 3, imagem 1 %32 InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: passo 3, imagem 2 %32 InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: passo 3, imagem 3 %32
    • Unhook the spring from the bulb housing.
    • Gently remove the bulb.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble the device, follow these instructions in reverse order.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 19
Ao todo: 143
